Sears has the Mityvac Fluid Evacuator Plus 2.3 Gallon Manual Pump operation on sale for $81.96.
But, this is not a Hot Buy, so you can get it much lower, and you can stack coupon codes and surprise points.
Most people should either have $10 or $15 in surprise points for $75 in Tools or Sears in general. And you should also have a $5 off coupon code for either $50 or $75 spent at Sears.
I got this for $61.94, after applying a $5 off $50 coupon, then $15 in surprise points on $75.
This item is very coupon friendly and surprise point friendly.
http://www.sears.com/mityvac-fluid-evacuator-plus/p-00942277000P?redirectType=SRDT
It works pretty good, there are some negative reviews from some people saying it doesn't evacuate well. I just used it today, and sucked out 5 quarts of transmission fluid in probably 2 minutes or less, with about 20 pumps or so. Then you can change directions, and pump the used fluid into a container. Very clean, and didn't have even a drop of ****** fluid spilled. This is so much easier and cleaner than dropping the pan.
