75gmck25
I have a standard efficiency Buderus gas boiler that runs water at about 135-140 degrees with my cast iron hot water radiators. I am considering using in-floor hydronic in a new addition, but my understanding is that it will have to run at a much lower temperature.
I have seen a few articles about using mixing valves to get zones with different temperatures, but none of them have a clear explanation of how it works. It seems like they may mix the return water from the high temp zone with the water going to the lower temp zone, but I'm not even sure that is how it works. I think my return water is probably about 100 degrees (IIRC), so even that might be a little too warm for in floor heat.
My boiler also has a minimum temp of 100 degrees when not circulating, so that the response is faster when the heat comes back on, but I know that minimum can be turned off.
Anyone have pointers to articles that explain the concept and physical setup when you use a mixing valve to get a lower temp in one zone?
Thanks,
Bruce
Thanks,
Bruce
