Mobile Tool Storage Help
TK-421
Pflugerville, TX
So I'm definitely way out of my league here and in need of some advice/ideas, and I figure asking more experienced people is definitely the way to go, so here I am.
I'm going to automotive classes at my local community college this fall, so I need to figure out a way to transport my tools there and back for classes. While they do have lockers there for student use, the way they've scheduled the classes I'll be forced to attend to two different campuses, so I can't just store them in the locker. Plus the fact that the lockers at my main campus are only 13" wide by 16" deep by 35" high, and I don't think there's any way I can store the required tools in a locker that small and still have them organization.
Organization is the key here, and that's why I'm having a difficult time. Sure, I could just toss my tools in a few duffel bags and call it good, but then I'd spend forever trying to find each tool I need. So I'd much rather have organization and have a spot for every tool, that way I know exactly where something is, and I know I've left it somewhere if it's not there.
Here's the list of tools I currently have: https://docs.google.com/spreadsheets/d/1ho0V6TPq8lwBTXAvejQt4yuuTa0jDlPOGTepc8b5ffE/edit?usp=sharing
That's not all the tools I need though, which is why I'm in a quandary, because I'm running out of room in the box I currently have, and I still have more tools to buy.
The tools I still need are 3/8" and 1/2" impacts, sockets and extensions for the two impacts, a 1/2" socket set and ratchet, a power probe IV, a fender cover, a bag for my jumper cable set, some scrapers, a multimeter, wire strippers, wire crimpers, a "T" gauge set, a ring compressor set, an oil pressure gauge set, a tap and die set, hose clamp pliers, hose pinch off pliers, and 3/8" and 1/2" torque wrenches.
Somehow I need to fit all those new tools, and all the tools I currently have, into some sort of toolbox system that will fit into the back of my car, with organization being a necessity, and being able to carry everything in one trip being a high priority.
This is the tool box I currently have, and it's probably about as big as I can easily fit into my car.
http://www.lowes.com/pd_336429-1156-9124SR___?productId=3355634&pl=1&Ntt=blue+hawk+chest
I don't have the option of putting very much in my trunk either, as I have a set of subwoofers that take up the vast majority of that space, so everything has to fit on my back seat and front passenger seat.
One idea I had was to rig up some sort of clamp system that would hold a second tool box on top of the one I have, but something a lot shorter. However, the problem with that idea is that the lid on my tool box is very flimsy, and I don't think it could support very much weight hanging off it when I pick it up to wheel it around.
Another idea I just had, though, is a b-train idea. Where I somehow rig up a tow system, so that I can hook a second tool box onto the back of the first system, and me pulling on the front tool box then also pulls the second tool box. The problem with that idea, however, is that the handle retaining system is fairly flimsy, and I'd worry about the handle either bending or plastic breaking and the handle pulling out of the box, due to the weight of both boxes.
I got an idea off the web of cutting up a bucket boss and attaching that to the interior of the box to get some storage along the inside walls, but that's quickly filling up, and I still have a lot of loose tools floating around that I need to find a way to organize them.
Here's the way I have the inside of my toolbox set up:
Here's part of the tools I currently have, and need to figure out how to shoe horn into this box:
The car I'm trying to fit this all into is your average size 4 door sedan, specifically a Mazda 6, and the 20" width of the box I currently have is probably the widest I'd want to go, any wider and I run the risk of accidentally putting a box lid edge through the window, or scraping up the inside of my door, both of which I want to avoid. I also figured out that both would be possibility when I purchased a Husky 37" Mobile Job Box, which is 23" wide, and had a massive hassle trying to load the empty box into my car, and realized that there would be absolutely no way I'd be able to load it into my car without damaging something once the box was loaded.
So, hopefully someone here has gone through something similar to what I'm going through and will be able to help me out, as I'm completely lost here.
one9gt
San Francisco
Are these general auto classes or broken down into seperate auto systems?? If they're seperate then consider a general box and then seperate boxes for specific systems.
Tenex
Ever think about making some stackable, wooden racks to fit your box?
T
TK-421
Pflugerville, TX
They're broken down into separate auto systems for the most part, but they all require a base set of tools in addition to the class-specific tools, and it's mostly the base set that I'm having difficulty figuring out to make things fit.
Here's the tool list: http://sites.austincc.edu/autotech/required-tools/
This summer I'll be taking AUMT 1405 - Intro to Auto Tech, AUMT 1407 - Automotive Electrical Systems, and AUMT 1419 - Automotive Engine Repair, so those are the tools I'm currently looking at trying to transport.
Ideally I'd like to eventually transport all of them, that way I have everything I could need, for a "just in case" kind of thing, but if that's not feasible then I'll want to transport the base set and each class's individual set.
This semester will be the fewest amount of tools I'll take, however, as after this I'll be doing four classes each semester, so if I can't figure out a way to transport the tools now, I'm kind of screwed for when I have another class.
One main box and a box for each different class is certainly an idea, though my memory is crappy enough that I know I'd be likely to grab the main box and then forget the second box, and then get to school with only half the tools I need. However, if I can't come up with a better idea, then I'll likely just have to figure out some system to make sure I don't forget a secondary box.
No, I hadn't considered that, which is exactly why I started this thread, I really like hearing new ideas I might never have considered otherwise. :thumbup:
Are you thinking just one stack of boxes that take up the entire width and length, or two stacks of boxes that take up the full width but half the length, to add more variety and try to save on weight so the boxes don't have to be quite so durable and thick?
DSLTRK
PHELAN, CA
Hi,
Congrats on your direction in life.
I think the issue you're gonna run into is socket organization. Sockets are small, similar looking, and easy to lose.
I'd get some canvas bags for your larger tools like ratchets/extensions/wrenches, and focus on a clear, clean easy way to access your sockets. A good idea might be to get some boards, drive multiple nails in them and then stagger them (like a shoe rack) to gain easy access.
DSLTRK
PHELAN, CA
Oh, and another thing, don't fall into the hype that you have to "buy the best to be the best". Tools are going to walk off during a semester. Ask me how I know.:beer:
I would have no issues using a Taiwanese socket/wrench set to get going.
T
TK-421
Pflugerville, TX
Hi,
My 1/4" and 3/8th" socket sets are Genius sets that come in plastic cases, so I'm not super worried about those. However, I don't have a 1/2" set yet, but if I get an impact set then do I really need a chrome set as well when I'm first starting out?
I definitely plan on picking up some tools from the big name tools, but mainly just the basic hand tools, and only since I'll be part of their student program and will be able to buy them for 50% off. I plan on paying cash up front, I don't want to avoid getting into debt as much as possible, and I wouldn't be surprised if I could find personal loans with better rates than what I can get on a truck.
Fortunately I'm not an impulse buyer, I tend to plan, and plan, and plan. I've honestly been researching things for well over a year, and have only been finally buying things over the past few months.
Do you have any advice for the best way to make sure stuff doesn't walk off? I plan on getting padlocks for my case for those times when I have to leave it for whatever reason, but my main idea right now is to try and not turn my back on it as much as possible, and to take it with me when I leave. Unfortunately, I think using a bullwhip on people who try to touch my tools would be frowned upon, so that's out. :lol_hitti
T
TK-421
Pflugerville, TX
Hi!
Just some Ideas:
What about a mobile tool box/workshop like the ones offered by Bostitch, Stanley, DeWalt or Stalwart?
http://www.amazon.com/dp/B008J2IPW6/?tag=atomicindus08-20
http://www.amazon.com/dp/B009CP4FAK/?tag=atomicindus08-20
http://www.amazon.com/dp/B00NOI33X6/?tag=atomicindus08-20
http://www.amazon.com/dp/B00WMLYFAQ/?tag=atomicindus08-20
Remember that you need to work out of the box, not just bring it ;) So your main concerns should be tool organization and accessibility plus staying within a reasonable/manageable amount of weight. Some of those boxes can be parted for ease of transport, given that you don't have much free space in your car. Maybe you should think about sacrificing those subwoofers... ;)
I don't think the Box you have right now is going to work out for your needs.
Kind regards,
Oliver
I looked at those boxes before i bought the one i have, but the problem with those boxes is they have pretty close to half to 3/4 the usable space that my current box has, and they have no way to easily carry a 25" long pry bar, so they're not going to work either.
vartz04
LaSalle County IL
What about one of these montezuma boxes? I may have missed it but what do you drive? They aren't cheap but for driving around and staying organized this would be the way to go. Then just use some small totes of some sort to hold whatever doesn't have a home in here. They sell these in all different sizes to meet your needs.
Tenex
In regards to the wooden trays, I was imagining a single tray per level, but they should be built with varying heights to accomodate different tools. I would designate a tray for sockets, hammers, screwdrivers, pliers, etc. Put your sockets on Ernst twist-lock rails to keep them organized. If you want to get real fancy you could do foam inserts for each of the trays.
vartz04
LaSalle County IL
This is also a very good idea....if you have the skills to make something strong out of wood.
sberry
Brethren, Michigan
See what it looks like after a day, you can prepare forever for stuff never needed or never happen. Quit giving big speakers a free ride, make room.
DBendr
LOL...Does this :school: have a list of "required tools".
I couldn't imagine a guy entering a program having to show up with impact sets.
Maybe second semester it's bring your own press and puller sets ?
Bobcat753
New Hampshire
He did post a link of what the school requires. Also some people like to have their own tools. Most of the time the school provided tools are beat to hell. When I was in high school taking metal fabrication I had my own grinders, clamps, hammers and quite a few specialty tools. My instructors knew I was serious because I would go out of my way to buy an expensive tool for a job or two when the shop didn't have it.
Also to the O.P look up military ready tool storage. that will give some good ideas on First Order Retrievability.
sberry
Brethren, Michigan
I am for having what one needs but no point in carrying it all every day. When I was in auto school I really had my stuff in the trunk, got a couple things as needed.
gte718p
This thing eats a ton of tools and is vey easy to keep organized. Throw it in the passenger seat. It is how I move my offroading tools around. I can and have rebuilt engines/trans and drivelines out of this bag. It is heavy fully loaded, but once you get it on your shoulders it is not a problem.
Get some good rails for your sockets. I've got old stock craftsmans and I've never had one fall of the rail.
http://www.amazon.com/dp/B0000DYVCY/?tag=atomicindus08-20
DSLTRK
PHELAN, CA
Either you ugly them up with engravings or buy cheap tools. Padlocks only keep honest people honest. It takes seconds for some random guy to swipe stuff out of the box when you'll be busy working.
T
TK-421
Pflugerville, TX
That's the list for the required tools, I need the basic tools, the ones for 1407 and 1419 by the end of May.
Personally, I don't mind getting all these tools now, I'd rather learn with my tools than shop tools. Plus, I figure my tools will be in way better condition than shop tools, who have been used and abused by who knows how many kids for who knows how many years. Even if the school provided the tools, I'd still look into getting my own anyways.
I have to get them sooner or later, might as well get them now, when I live at home and have a fair bit of disposable income, and can buy my tools with cash rather than credit.
grich
I use one of these everyday for my job and love it. I went from carrying two bags with straps to one bag on wheels:
Husky 22 in. Pro Grade Rolling Tote from Home Depot
Sent from my SAMSUNG-SM-G900A using Tapatalk
tonyciambrone
Northern Illinois
Couple thoughts:
1: I am in a community college program for Auto and our required tools are much less extensive. I also have yet to use about half of what we are required. I'm really surprised they have you bring things like a ring compressor or valve core tool etc. Someone must be in bed with the tool suppliers? Funnels? Is every student planning on starting their own shop?
2: from the list it looks like you are carrying 3 pry bars when it only calls for one and a couple other instances like that. Trim down to the absolute minimum and add tools that you end up wanting. I ended up adding a scratch awl for marking parts, and a few pliers/universal extensions that were not required.
3: we have never been checked for all required tools and I highly doubt we ever will. Your school may vary but if it's the same way don't stress. Also I share your affinity for Mayhew tools and the like so at least you are buying good stuff.
T
TK-421
Pflugerville, TX
Couple thoughts:
I don't get it either, but the professor said they're required, so I guess I better get them. Although I will probably try and set up a tour or something, that way I can sit down with the professor and talk about the tool list and see what I can not buy.
They came three in the set and were cheap, and I figured I could jam them into a gap that wasn't being used for anything else. I'm mainly trying to not only get tools I need now, but will also need once I get out of school and can find a job in the real world. I'm living at home, so my bills are negligible and I have a fair amount of disposable income, relative to what I'll have once I move out. So I figure I had better buy as much good quality stuff as I can, because I won't have such an easy time dropping so much money on tools once I have real bills and responsibility.
I'd honestly be surprised if we get checked for tools, but I figure if I have to buy it then I want to buy quality, there really isn't much sense to buy now and then buy again when I get a real job, so I might as well buy job-quality stuff from the start. It hurts more now, but it'll be less expensive in the long run.
vartz04
LaSalle County IL
You have a good train of thought. Maybe it's time to get a small SUV? Then you could set a small top box something in the back? How close can you get to the shop with your car?
T
TK-421
Pflugerville, TX
I would get a small SUV if I could, but, unfortunately, I'm too upside down on the car I currently own. So I'm stuck with it for the foreseeable future, until I can get a better paying job and can put more money into my car payment to get it paid off so I can get something better.
I can't park close, here's a map of the campus, I'd be having class in building 5000 and park in Lot D.
https://drive.google.com/file/d/0B5HXgwuT7shiT216VXA1OUUzb3lYN3Y3cHhSd3ZsUGJEOHdn/view
It's not a super long walk, but longer than I'd want to carry something if I instead had the option of rolling it. It's also a long enough walk that I'd want to be able to take everything in one trip, rather than leave tools unattended while I make a second trip.
Finky198
North East
I have and use the pelican 0450 it's a Great box, but as said before it only holds hand tools that's with or without the foam and in a limited fashion regardless of your "Tetris skills"
Not to mention all of my prybars, breaker bars, impacts guns, impact sockets, 1/2" chrome, electrical tools, hammers, and specialty tools are all stored on a shelving system outside of the pelican case. Thus it not very functional if you really need to travel. It also doesn't help that fully load the case weighs more than I do @ 175+ lbs it's not easy to load into a vehicle let alone roll it which is def not gonna happen.
I'd like to give you a more positive outlook but I hate to say this but your kind screwed. That's a lot to stuff to move around all the time. Best of luck...I mean your trying to move a small truck load / 72" tool box full of tools without the actual box. It's gonna be one hell of a magic trick
Here's a few pics just for reference these are not very current but... there are 3 more drawers one drawer of picks punches and chisels, one of screwdrivers, and the large drawer with cutters and specialty hand tools.
Here's the shelving unit with the extra stuff
Finky198
North East
The trick is that office staff should not have let him signup for both courses :scared: knowing that there would be a scheduling and location Issue. Unless you possibly did this to yourself :eyecrazy:
If it was one course he could buy a tool box leave it at school, then transfer it to the other campus when the first course is over. But why work smarter when you can work Harder!!!
I worked out of a small suv for a 1.5 years with said pelican case ^^^ it was more work just to transport my tools then it was to actually do the repair work.
Air21
I have this bag for my aircraft wrenching tools. I love it. LOVE it. In the hangar its just 3 zippers and I can reach any tool right away. It's tough, easy to carry, its a win!
Finky198
North East
If you can get a pelican 0450 for cheap (there 599 new) and fill it with the bare bones of tools then get your self a large canvas work bag for your impacts, pry bars, specialty tools
If you could ideally get the weight under 75 lbs It could be manageable with the wheels not fun or easy but you could make it work. problem then being your car and how to get it in and out without doing any damage to you car, box, or yourself...
I travel with it for about a year and a half, but it rarely left the back of my Jeep GC I had two pad locks on it and a chain to the floor pan. it worked pretty nice for a moblie shop with some additional thing, but I would not want to have to pack and unpack that load daily :wtf:
T
TK-421
Pflugerville, TX
Three courses, two at one school and the third at the second.
Because the place I can get to store my tools at school is 13" wide by 16" deep by 35" tall. If you can figure out some way to shoehorn this list of tools http://sites.austincc.edu/autotech/required-tools/ into that space, I'm all ears, but I certainly can't do it.
Plus the fact that if I took one course at a time, it would take me 15 semesters, or 7.5 years if I don't take summer semesters, 5 years if I take summer semesters. Or, I can take more than one class per semester, and have it done in one year.
Like I said above, if you can figure out a way to shoe horn all those tools into a locker that small, I'd honestly like to hear it. However, as it sits, my box is 30.5" x 19.25" x 19.5", and I'm still having a few issues making it fit while keeping it organized, let alone figuring out a way to cram in the stuff I still don't have.
derosa
Oceanside, NY
Want to keep track of your tools the break out the dollar store nail polish and apply liberally. All tools at the bicycle clinic get a solid coat of pink, a stripe is added to designate a particular workbench. Specialty tool is missing start scanning the other benches for a solid pink. My personal tools are green, no one can argue a wrench is theirs when the whole handle is your color.
Buy enough you can dip your sockets, shove cotton balls in the opening of each socket and pull the cotton out before the socket dries. Candy apple red will show up on the rim of a socket from across the room. Polish holds up well to abuse, even better for organized tools and is semi-easy to remove with rubbing alcohol.
Finky198
North East
What Your essentially trying to do squeeze around a 100Lbs of tools into a box and possible a bag and make it easy to move around. let alone have it organized and not move during your constant transporting in the car and to and from class. Having to reorganize your box each trip is not realistic. Be very mindful time is money in the auto industry.
I'm am not try to be mean, but I don't see good things coming out of this situation unless you can some how compromise by dealing with less tools or leaving certain items in your locker, or Maybe its time to take the subs out of you car so you have functional space...
Stuff never fits back In properly when your stressed or in a rush so you better factor In time to carry all this stuff to and from. As well as to pack/unpack everything each trip.
One thing might also want is a check list so you can account for your stuff. U don't want to start right off the bat loosing tools.
As the guy above said Nail polish is great for marking your tools. And best of luck to ya...
T
TK-421
Pflugerville, TX
It's a $49 Stanley rolling box, with a bucket organizer cut up, and hung on a piece of flat aluminum stock that I bolted to 3 sides of the box..
I'm pretty sure it was your pictures that gave me the idea to do the same in my box. Do you remember which brand organizer you went with? I used a husky from home Depot but it doesn't seem as useful as the one you used.
T
TK-421
Pflugerville, TX
The weight I won't have any issue with, I'm big and brutish enough that I can make do. It's the organization without a ton of wasted space that I'm more concerned about.
619DioFan
San Diego , Ca.
My advice is to go to the school and see what the current students are doing in regards to their tools. might find that someone has come up with an idea that works for you.
crewchief888
NW indiana
after reading through the thread, this makes the most sense to me.
personally i cant believe some of the stuff thats on a required tool list.
we've hired a couple kids right out of tech school that didnt have much more than a claw hammer, a bent screwdriver, half set of 3/8" dr chrome sockets with a broken ratchet.
they didnt last long....
:beer:
bb_max
central IA
Every tech school I've heard of lets students keep a roller tool box in the shop. Get one and put it an the campus where you'll be most often or using most of your tools.
When you go to the other campus, take what you need in the box you have. You'll figure out pretty quick what you need or what you wont need. You wont need it all on the first day, or first week.
Make friends. Borrow something (pretty much against the advise of everyone here) if you don't have it with you.
kctyphoon
Jersey/Staten Island
Sorry for the late response... Everything I used was from HD.. It's a $9 or $6 husky bucket organizer that I cut up and used.. Cut flat aluminum stock to length and bought some cheap nuts and bolts.. I folded the top of the nylon(?) organizer, and marked where I would place the bolts. Then I held one of the bolts with pliers, heated it up with a lighter and burned a hole for the bolts so the drill bit wouldn't rip it open and it melted the nylon so there wouldn't be any rips around them. Placed the aluminum rail in the fold, and marked the holes with a sharpie. Drilled the metal rails, then used the rails to mark the holes in the rolling box.. With better boxes available now, I'd go with a dewalt or a husky now..
I sucked it up and bought one of the tool carts on at HD when they were on clearance, and I'm in the process of outfitting that now to use in the driveway.. I might even buy a small Rubbermaid box for the driveway to keep it in when springtime rolls around..
