Model A Ford garage
drivesitfar
BB: that stain sure looks good and dry too. since you were in short sleeves and the stain dried fast is it warm again in your part of the world?
the mill is really looking good. WELL DONE!!
bolensboneyard
South East
Thanks drives. It is in the mid seventies right now. It has also been dry for this area with a balmy breeze. When spring hits it will soar. I am taking advantage of it while it is tolerable.
bolensboneyard
South East
Wow! That mill looks brand new. Is that the reversing pulley that's still got the paint?
Thanks Andy. Sure is I have the track beds on and the tracks on the blade side are on temp. so I can run the carriage by hand and check for blade parallel. I set the tracks yesterday and squared them up with the mandrel. Bed is level both ways. Some minor bends in the track. Going to try to run a dial indicator along with the carriage but as the saw blade is hammered with a bell accuracy will be questionable. I figure the closer I get it the better.
bolensboneyard
South East
Bobby I just luv what you have done that has been one fantastic effort..:bowdown:
Form, Fit and Function..:thumbup:
Thanks Steve. Will post pictures as of yesterday. Plan to install the ratchet and dog assembly today then build the addition over the last six feet of track bed next week.
bolensboneyard
South East
A dial indicator placed on the carriage gives me a reading of .008 run out on the machine face of the backup washer for the blade! When the indicator is placed on the same surface and the dial is taking a reading along the edge of the moving carriage the greatest change in direction of movement is less than .100 for the entire length!
bolensboneyard
South East
Yesterday was great fun! The balance on the blade is perfect. It takes forever to stop with a small spin and when it does come to a stop is settles back with a backlash of one inch. The spin within the guide pins varies no more than a few thousands.
Bob Heine
Boca Raton, Florida
Bobby, I know about sawmills like I know about submarines (I can recognize them) so this is just a know-nothing comment.
The power plant for your mill looks like a Ford inline 6. I am sure the saw needs that much power to run at full capacity but is it possible to have an electric motor (maybe 5 hp) run the saw for smaller logs? I'm thinking a belt drive with an idler attached to one more big handle. If you have a couple of 8- or 10-inch logs to square up, you wouldn't need to run the engine up to temperature. Gas engines, if I recall correctly, "wear occurs in the first couple minutes after a cold start. Rich fuel mixtures wash lubrication from the cylinder walls."
For proof of concept maybe turn the blade with a gear-driven 1/2-inch drill (or larger) drill. Once the blade is up to speed, wouldn't it cut for quite a while?
oldironfarmer
Terlton, Oklahoma
Submarines do use 5 hp motors, Bob.
A circular saw does take a lot of horsepower to make a 1/4" wide cut with any speed into a log.
But the main reason to cut with an engine is the sound it makes when the governor kicks in and it opens up as you enter the log. That's why sawing logs is such fun.
Bobby:
What's that big plate with the fancy cutouts around the edge? It's real pretty. Is Ginny going to paint a woodland scene on it?
P.S. Hope you've got lots of inserts so you don't get stressed when you bust a few.
I can smell the sap...
oldironfarmer
Terlton, Oklahoma
Bobby that is one mean looking saw blade
[ Andy quote: that big plate with the fancy cutouts around the edge]
:scared:
Steve, the fact that English is your second language is showing. You should have said I "saw the blade" or "I gave the blade a mean look" or "I saw the blade and it looked mean". A mean looking saw blade just has verb and tense problems.
:bounce:
bolensboneyard
South East
Bob I have seen them run with electric motors but low RPM is needed and high torque. Usually older extremely heavy motors with gearbox reduction and higher HP.
bolensboneyard
South East
Bobby:
Andy I assume you are referring to the steel plate after the blade and board spreader/separator? No fancy cutouts just radius corners. It is for kicking out boards that have been sawn from the log so that they don't fall into the blade and become missiles. Used instead of a table as I have no helper and am still able to bend over and pick them up off of the ground. :dunno:
bolensboneyard
South East
View of saw mill from the end which will be covered by the shed show in part for perspective. I will post pictures by morning of progress over yesterday and today. Have another friend whose wife has been diagnosed with stage 4 cancer. Please pray for Jane and Frank. They are close to us. Thank You all. Bobby
drivesitfar
BB: very sorry to hear about your friends. at our age it seems to be a more common thing to get bad news about friends and relatives health. here's hoping she beats the odds.
WOW I thought you were just going to build an overhang and it looks like you already installed another couple huge posts.
the saw is looking great and I bet you are excited to cut some wood with it.
good luck!!
oldironfarmer
Terlton, Oklahoma
My condolences for your friends. We've been there and it is not much fun.
The fancy cutouts I was referring to was intended to be the blade. I was just trying to be funny and that seldom works for me.
Lyndon
Sydney, Australia
Bobby
A stage 4 diagnosis is never good. I'm not very good at praying (I don't think I have much credibility up there... :dunno:)
But I will say I'm sending our best wishes to your friends, and hope that they have the same family and friend support that I received after my similar diagnosis, and that they have a positive attitude to the whole process. If it hasn't yet mastastisised there is still hope.
Keep the chin up, and look for the funny things in the coming months.
Lyndon
Yep - still here.
bolensboneyard
South East
good luck!!
Drives I am excited but want to take my time with the power plant. I also have a lot to do that needs to be before the hot weather; such as sand and paint the barn roof repairs and fix the other side. I plan to wait for cooler weather to work inside on the power plant and save the nicer outside weather for building a bench to build the kayak.
bolensboneyard
South East
Bobby
Lyndon
Yep - still here.
Thanks Lyndon. The nice thing about "up there," we all have credibility.
bolensboneyard
South East
Check out the corners on this shot of the shed. I needed to get the taper in on a 45 to match the sides but wanted to bring down the header without offsetting the look of the whole thing. I decided to "sign" the project with cutouts that look like the teeth on the saw blade and blend the whole trim in at the same time! What do you think? Car show this weekend for the GT so prep tomorrow. Today will finish the face board and furring for the roof panels. Hard to see the lower angle on the cut. Look close it cuts back on a smaller 45 degree angle.
bolensboneyard
South East
Bobby:
Andy, I finally found them. I did get a box with seven teeth inserts in it with the mill. Thought I had remembered but wanted to check before I responded. :beer:
