Modern and specialty caulks
roc_on_the_rocks
South central Indiana
Hey guys,
I have an aging wood-sided house that needs some of the external window trims re-calked and came across this article from the Family Handyman magazine (Jul-Aug/2018):
How To Choose the Right Caulk For the Job
Here's the summary:
What Are the Most Common Kinds of Sealants?
These types of caulk dominate the shelves at tool supply stores. Labels don’t always tell you what’s in the tube, so we’ve included examples of each type of sealant.
Acrylic Latex ($2 to $5)
Acrylic latex caulks are the easiest to apply and smooth out. They’re also the only sealants that clean up with water. Look for versions labeled “siliconized” or “plus silicone.” Adding silicone to acrylic latex improves adhesion and flexibility.
Example:
Polyurethane ($6)
Poly caulks are generally tougher than other sealants, making them a good choice for driveways and other areas that take a beating. But their gooey consistency makes them hard to work with. Check the label before painting; you may have to wait several days.
Solvent-Based ($6 to $9)
Many solvent-based caulks are great for roofing because they don’t degrade in direct sunlight and can be applied to wet surfaces. But they’re gooey and hard to apply neatly.
Hybrid ($7 and up)
Most hybrid caulks combine silicone and polyurethane for top-notch adhesion, flexibility and longevity. They’re easier to apply neatly than polyurethane, but not as easy as acrylic latex. Most aren’t labeled “hybrid,” so we’ve pointed out the hybrids in the various photos. Cost is a clue: High-quality hybrids are usually the most expensive caulks on the shelf.
What is the Best Caulk for Painting?
Choose acrylic latex
For just a couple bucks, you can find a caulk that dries fast, is easy to work with, easy to clean up and can handle a little movement. Alex Plus is one good choice, but there are several others. If you are dealing with a large recurring crack in a wall corner or in a crown molding joint, choose a product with better flexibility such as a hybrid formula or Big Stretch acrylic caulk.
Examples of latex sealants: DAP® Alex Plus and Big Stretch by Sashco (for large cracks likely to move/open)
What is the Best Caulk for Siding and Trim?
Choose a hybrid or polyurethane
On a home’s exterior, high-quality caulk is critical—it locks out water, protecting homes against rot and peeling paint. Although some inexpensive acrylic latex caulks are rated for exterior use, we recommend hybrid caulks because they offer better adhesion and flexibility. For matching the appearance of materials like stucco or rough-sawn wood, we like Vulkem, a textured polyurethane.
Example of hybrid sealants: OSI QUAD® MAX - Window, Door & Siding Sealant and DAP® 3.0™ Window, Door, Siding & Trim
Example of polyurethane sealant, for texture: Vulkem 116
What is the Best Caulk for Kitchens and Bathrooms?
Just check the label
Caulk in kitchens and bathrooms is often visible, so choosing a product that’s easy to apply neatly is important. It also needs to be waterproof and mold and mildew resistant. Choose a product labeled with those traits. Acrylic latex kitchen and bath caulks are the easiest to work with, but hybrids generally have a longer life span.
Example of hybrid sealants: DAP® 3.0™ Kitchen, Bath & Plumbing
Examples of siliconized acrylic latex sealants: KWIK SEAL ULTRA® Advanced Kitchen, Bath & Plumbing and Loctite Polyseamseal Tub & Tile Adhesive Caulk
What is the Best Caulk for Concrete and Masonry?
Choose a specialty caulk
A caulk specially formulated for concrete and masonry will outperform general-purpose products. Most concrete and masonry sealants are polyurethane or hybrid formulas. But one acrylic latex product, Slab, also performs well, especially on concrete cracks that move a lot. Some concrete and masonry caulks are self-leveling and can be used only on level surfaces.
Example of polyurethane sealants: Loctite PL Concrete Self-Leveling Polyurethane Sealant
Example of hybrid sealants: DAP® 3.0™ Self-Leveling Concrete & Masonry Sealant
Example of acrylic latex sealants: Slab® - Concrete Crack Repair Caulk by Sashco (for cracks that move a lot)
What is the Best Caulk for Roofs?
Choose solvent-based sealants
Any caulk that lives on a roof is going to get hammered by the elements. It needs to be able to survive extreme exposure to sunlight and temperature variations yet remain flexible. These two recommended products can actually be applied on wet surfaces!
Example of solvent-based sealants: Through the ROOF!® by Sashco
What is the Best Caulk for Gutters?
Go with a hybrid or solvent-based product
It’s no surprise that a product designed to seal gutters needs to be 100 percent waterproof. But it also needs to be tough—tough enough to handle the abrasion from debris and ice in colder climates. Most gutter sealants do a good job on metal, but not all will adhere to plastic gutters. Be sure to check the label.
Example of solvent-based sealants (for metal or plastic): Through the ROOF!® by Sashco
Example of hybrid (metal only): DAP® 3.0™ Gutter & Flashing
They end the article with this:
Are Silicone Sealants Any Good?
Years ago, silicone caulk was a good choice for many jobs. Today, there are better options for almost every situation. So why is silicone still so popular? Here’s what one manufacturer of caulks (including silicone) told us: “Silicone is what our customers saw their fathers use. It’s what they’re familiar with.”
I hope you find this informative. What are your favorite calks?
PS.: The hyperlinks (in blue) are functional.
CraigStu
Blacksburg, Va
Thank you, thankyou, thankyou. I copied this in to a word doc and saved it. Just last Monday I spent 15 min looking at all the caulks at HD trying to find the best to seal plastic gutters. Quite a few mentioned gutters in their uses list but not plastic gutters. Found a clear that is working out well.
yeldogt
Whenever you think caulk --- think again about what you are doing and how long it's going to last.
It's wildly overused and can cause more problems ... I see caulk around the tops and bottoms of windows and doors all the time. Especially interesting with Vinyl siding jobs since all the siding leaks anyway. Sealing the bottom trim of a garage door surround .... people think caulk stops water .... it slows it down. Most times the overuse of caulk traps moisture and causes what you are trying to stop
Roofers use it everyplace imaginable .... and for the most part is never needed if the roof is done correctly.
I agree on the polly stuff -- good products .... but they are basically almost a glue and can be a pain if you make a mistake ....also -- some are exterior only.
Personally -- the Sika products are my normal go to. And I still like Silicone for some items in kitchens and baths (setting under mount sinks) . Inside -- Phenoseal is still my go to pre-painting caulk
Jlarson
Sika 1A and 15LM , Quad max, Vulkum 116, and Boss 380 silicone. But then again I'm a civil construction guy at heart.
yeldogt
That is a great line.
I've seen it many times where a well intended caulk job ends up trapping water rather than keeping it out.
Even the home shows ...like THO ..... Tom starts with the caulk gun. Everywhere -- he loves the stuff.
R
roc_on_the_rocks
Hey guys,
Here's the summary:
Example:
Polyurethane ($6)
Hybrid ($7 and up)
Examples of latex sealants: DAP® Alex Plus, Big Stretch by Sashco (for large cracks likely to move/open)
Example of acrylic latex sealants: Sashco Slab® - Concrete Crack Repair Caulk (for cracks that move a lot)
OP here... I updated all links, hope this helps someone.
MerlinsBeard
MD
Following up on this caulk thread. So I have an issue where I get periodic GFCI trips because one of my outside receptacles is caulked and one is not. When I plastic off the receptacle that's not caulked, I don't get the GFCI trips. It's annoying because they connected that GFCI to the garage door outlet as well. It's taken me too long to figure out what's going on, and I've been lax to fix it since I didn't want to buy caulk just for that outlet. I do eventually plan put the backyard receptacles on it's own GFCI, but I'm not there yet.
So it's coming up on 10 years and I'm looking to refresh the external caulk situation. The caulk is color matched to the siding. It's getting about the time to re-apply and I'm looking for the "best" external tintable caulk that I can buy (ok maybe the top two options if there is serious sticker shock). I have a siding sample that I can bring to help color match. I see several options but don't have the experience to select the best. What should I be going for?
PoorUB
Fargo, ND
Sikaflex LM, Dap Dynaflex 230 are two of my favorites. I use very little silicone. Once you start using other caulks like Sikaflex you will pretty much stop using silicone!
I caulked up a couple roof jacks with Sikaflex LM on my roof 20, years ago and the caulk is still holding up well.
ptabatcher
NE Ohio
You might want to check and see if OSI already has something: https://wheretobuy.ositough.com/quadmax-color-cross-reference.pl
