Bottlecapdigger
This has been an issue right from day one when I first got this, the issue of the deck scalping and ripping the sod as the centre "shoe" drags along. The the mower deck does not have a roller at the front centre. I believe they did not use this because of the drive over deck and didnt think it would be strong enough to support the tractor driving over it. I tried making a larger shoe or now we can call it a ski to see if this helped, well it helped a little but not much better. I was reading on different JD forums and this seems to be a common complaint with other JD owners with the drive over decks. The following pics are what I came up with, I made it sturdy enough to support the tractors weight and figured the roller would just push into the sod with the tractors weight on it. I left the "sod scaper/shoe" on behind it as it can help support the weight also. The roller is about 1/2-3/4" lower than the shoe. I'm going to try it later today and I'm quite confident that this will eliminate the sod scraping. I will let everyone know if this works, and if it does your welcome to post this on a JD forum as im not a member on one BCD
