Modifications to Drill Press
thinkracing
McKinney, TX
I think the best modification one can make to a drill press is a deadman switch. My Edlund came with one and it's been a nice thing to have a few times. :)
x2
Harbor Freight sells these for $12. I put one on mine.
W-Cummins
Iowa
x2
Dam, I didn't know that HF sold A&B foot switches I thought they only sold cheap imported **** from China!
BTW the best setup is a drum switch like Charles, and a momentary foot switch like the A&B model.
That way you can power tap with your HF drill press :):)
William....
mkdive
NPB (Socal)
Well this is not really that spectacular of a mod to my DP, but it holds a couple indexes I have in a handy spot. Before I made this I kept all my drill bits on a shelf about 10' from the DP, was a PIA to walk back and forth. Doing some yard work the other day I found this wire cage under some vines on the side of the house. It looked like it was originally intended to be used with a peg board storage setup. I clipped a couple wires off, tacked on a bracket then shot some gloss black on it. Works great for what I need. :)
Now my next project is to either make a larger t-slot plate to bolt on to my existing table, or buy just buy a larger table that has a few parallel t-slots. I think in the next week if I don't buy a table, I need to visit my FIL and use his Bridgeport to make one!
A friend actually gave me the mag chuck yesterday, 6"x12". Nothing moves when the thing is on! Amazing how strong they are!
PCO6
Newmarket, Ontario
Nothing unique but I have done a few things to make my drill press easier to use. One is that it sits next to my shop press. Under that I have a roller cabinet for storing drill bits, jigs, drill related tools etc. The top is convenient as a work surface while I'm drilling and of course the cabinet rolls out for when I need to use the press for long items. I also put my drill press on a roller stand so I can move it out on to the floor for good access. I added the adjustable "roller arms" to support long items that are being drilled. The wood block in the photo will be drilled to hold bits (not quite done yet).
mkdive
NPB (Socal)
I have a block Im going to do the exact same thing with...Ill screw it to that "cage" on my DP, drill some holes in it. I have a bunch of bits floating around the garage.....will be good to give them a new home. :thumbup:
PCO6
Newmarket, Ontario
I bought a metal drill bit guide something like the one pictured below and will screw it to the wood block for easily identifying the bit sizes ... and what's missing.
