terabyte
Parts list
HF 20Gal Parts Washer
3 gallons of Orderless Mineral Spirits
2 feet of 1inch I.D. hose
Mr. Gasket 7693 Remote Oil Filter Mounting Bracket
Movers Dolley to take casters off of
2x2 square tubing 11gauge
3/16 angle
melamine scraps
plywood scraps
2 buckets
3x8inch pvc compressor hose
assorted 1/4inch hardware
several brass fittings
requirements
so I wanted to use mineral spirits, I wanted a big basin if I needed it, I wanted fluid to come out from the brush, and I wanted the mineral spirits to be mostly self contained, oh yea I wanted it filtered too...
extra motivating factors
Mineral Spirits is damn expensive, if I had bought the 10-15 gallons of MS that it would have probably taken to use this parts washer as intended it would have cost me a lot more than what I have into this closed loop system...
build
i cut the bottom 2 inches off a bucket and drilled about 15 .75inch holes in it. i place this in the bottom of the other bucket so that the pump would be lifted off from the bottom where all the sediment would collect. I left the HF pump assembly as-is with the foam filter and everything. the HF pump outputs via a 1/4 pipe thread to the orange compressor hose. this goes into the car filter and then goes to my ghetto homemade but effective brush.
Mobil1 filters look pretty badass if you take the decal off
3/16 angle
melamine scraps
plywood scraps
2 buckets
requirements
build
