franksinatra
Yep, post 3,753 about what size heater do I go with. Seriously though, would you guys give me your thoughts. Im in Minnesota and the temps routinely drop below 0. When I add that info onto a few of the online heating calculators, I get some crazy recommended BTU numbers. I have 630 square feet with 11Ft walls. Pretty good insulation and insulated garage doors. I had planned on going 60,000 BTU but interested in everyones thoughts on going with a 45,000. I spend lots of time in the garage and open the doors several times a day during the winter months to get the car in, snowmblowers out, etc. My concern with the smaller unit is not enough heat to keep up with the demand and continuous cycling on the bigger one.
My other question is about the two 60,000 btu models I had listed. Menards has the Beacon Morris for 639.00 with 11% rebate. I can pick up the Modine hot Dawg heater for 659.00. Is the modine a 100.00 better? I have had Hot Dawg Heaters in the past. I have been very pleased with the heaters and I know parts are easy to get. No experience with the Beacon Morris models. Thanks for your help.
