HotRodHudson
- Joined
- Nov 18, 2013
- Messages
- 373
This morning I went out to the garage & found the heater not working. Gas wouldn’t even blow to be able to be lit. I decided to unplug the unit for a bit & try again this time here’s what it did.
After plugging it in I observed; the pre ignition fan kicks on & runs briefly, then the igniter glows red, gas turned on & flames lit as it should. However, this is where something goes wrong as the fan to blow across the hot exchangers never kicks on. Note: this unit is a 75k btu heater, around 12 years old but only put into service late last winter. After installing it I did notice a few drops of oil from the fan on the back of the unit, but that was all & dont know if that’s related.
After it ran the above time any subsequent times the failure occurs were gas should kick on but isn’t. Then the purge fan as I call it, keeps running for 2-3 minutes or more & shut off. Seconds later it starts the process again but this time the gas lights & bows as it should but again the fan on the back doesn’t turn on. After a couple minutes it turns off the gas & purge fan runs a few more minutes.
Since I’m in Montana & it’s getting below freezing at night, any help would be greatly appreciated!
