I am having and issue with a Modine HD60AH0134 natural gas hot dawg heater. The unit will power on, pre-purge fan start and sound good, I can see that the green light on the gas valve flashes bright then dim then bright then dim which I believe is normal operation. Once the hot flame ignitor turns on the gas valve opens and the burner will light, all 4 burners light and the flame sensor is in the flame correctly. Approx 5-10 seconds after the burner lights it will shutdown, the purge fan continues to run. This sequence will continue for 6 cycles and then the unit will lock out.... I am not able to find and type of bad sensor or safety.. .Can you advise on what the issue could be.. or can you provide some trouble shotting steps.
I have confirmed that the flame sensor is good and that the polarity is correct
Anyone have any thought on what could be my issue?
Thanks
Dave
Thanks
Dave
