Hi, I'm looking for help troubleshooting Modine HD 75AH0134 garage heater. I've owned the house for the past 10 years, and never had it running. I have no idea if it ever ran before. It has LP connected with internal gas valve converted to LP. I get no gas on the outlet but there is 10psi on the inlet side during ignition cycle. Ignition element heats up to glowing red but no gas is released to burn. I replaced the valve with brand new unit and same behavior. Also new transformer, no change. Exhaust fan and vacuum swith work, main blower and delay switch work. Rollout switches also work, and bypassing them also doesn't fix it. There is no visible damage or heat discolorations anywhere. I also installed new digital thermostat The only thing that i noticed is that despite transformer outputting 24v AC, voltage drop exists on some connections like for example on rollout switches and exhaust pressure switch. At these I measure 14v not 24v. Is this normal or a sign of something wrong and if so, what could be causing this voltage drop?
