Modine Heater
dropride
NH
I found a good deal on a Modine PA75, only problem is it's natural gas and i have propane. Can it be converted to work with propane? I've searched but haven't come up with much info.
ksp
NW Iowa
I know the Modine Hot Dawgs can be converted back and forth but not sure on that unit.
HoosierBuddy
Southern Indiana
I'd find out for sure before I bought it, but I'd say there is a 99% chance it can be converted by changing or brazing and redirlling the burner orifice(s). Propane runs at a higher pressure and will therefore need smaller orifices to meter the correct about of fuel into the burner assembly.
Phil
theblur98ss
If you can get the numbers off the gas valve I should be able to check and tell ya.
Maulerman
West Michigan
Modines are good units, however they odd in that all the ones I have seen use 120v control voltage instead of 24v. Be careful of that.
D
dropride
NH
Thanks for the info guys, waiting to hear back from the guy for more specs on it.
