Modular, low ceiling car shop suggestions
saruken
Hi everybody. First post here. I've loved reading all the build threads on here for a long time, and I'm finally to a point where I've got something of my own I'd like to share and get feedback on.
So, I recently moved into an older house (built in 1942) with an unfinished basement. It's sort of a garage, as it has a small garage door at the end of the driveway, but most of the basement is open, so there isn't really a garage "room" walled off in any way. Also, because the house is older, the dimensions are kind of odd.
There's no finished ceiling down there, so the floor joists are exposed and there are various pipes and support beams all over (and in one place you can see the bottom of the bathtub upstairs), but the "ceiling" such as it is, is very low. 6' 6" to 7' in most places, and just about 6' in some. The layout looks like this:
I really want to set up a little car shop down there, in the main ~ 22' x 11' area. But it's got a few stipulations. First of all, the limited overhead room and narrowness of the space are big constraints. Here's a shot of that area:
And second, I probably won't be in this house for more than 2 years. That's enough time that I don't want to be without a shop, but not long enough to make it worthwhile to install any permanent fixtures like an in-ground lift. Thirdly, as of now there's only one power outlet within reach, which is on the wall between the laundry room and shop areas, so that needs to be addressed.
The primary purpose of the shop will be auto work, and fortunately I have a suitably tiny project car (1972 Mini Cooper S). I also want a table for welding and clamping/hammering various metal bits somewhere, but otherwise I'm open to any arrangement.
As of now, I have almost nothing in terms of equipment. Just some basic car tools I keep in a couple old junky boxes. This is the first "real" garage I've ever had, such as it is, so it's already better than working in a driveway or a backyard.
SO.
If you've been patient enough to read all that, I thank you. I'm hoping someone can give me some suggestions on what I can do to make this space into a workable shop area, despite its limitations, and do so perhaps with some type of modular fixtures that I can disassemble in a couple years and take with me to my next garage.
Any thoughts and suggestions are welcome! Here are some more shots of the basement/garage area:
600SL
Connecticut
Well a lift is out of the question but still has the makings of a good shop. The basement I had in CT had 6' ceilings. The main thing you will need to do is to provide good protected lighting with shields. You will probably need to upgrade electrical down there. Being underneath a house pay attention to fire protection especially in areas where you will be welding.
S
saruken
Thanks for the advice. Great tip on the protected lighting. I would've had to break something to learn that myself. I will definitely have an electrician come out and inspect the wiring-- hopefully I can get some new outlets while we bring everything up to code. Also the place seems to have had the wiring updated some time ago, while still keeping some of the old system. There are two fuse boxes, one of which uses some pretty old-looking stuff:
Also the old main power line is still attached through the basement and just hacked off.
Is that normal? First time homeowner here, so forgive my dumb questions.
Kinyocase
Missoula, MT
I can't help you with your question, but the only dumb question is the one not asked. However I would speak with your electrician about that when you take your walk through with them. I am sure that it is safely disconnected at the other end, but definitely something to bring up to him.
bczygan
DETROIT! Arsenal of Scrappers
2 years is barely time to get set up.
First, where are you? Looks like it would be a cold place to work. Needs some way to at least temporarily insulate and seal and heat it.
Second, I wouldn't worry about finishing floor, walls or ceiling. Just hook up adequate power and lighting and bring your equipment in.
Any benches or storage you build, make it portable or movable, not built in, so you can take it with you later.
I would go to the effort of painting everything I could, with a white paint, for better lighting.
This wouldn't be a showplace, just a work space. Think temporary. Run cords and hoses rather than permanent wiring and piping.
Put our money in the equipment and movable storage and work surfaces.
You could also use things you will discard when you move.
Get some free dressers and an entertainment center from the free section of CL. Dressers become your workbench and entertainment center becomes storage. File cabinets are cheap storage too.
Mount lights between the ceiling joists.
Insulation? I would be tempted to hang kraft faced batts, free and suspended from the exposed floor framing above, along the perimeter walls. Then cover with white visqueen sheeting or even white house wrap, for a cheap way to get a blanket of insulation around me and lighten up the space with the white cover material. Just let the batts hang down to the floor and maybe tape the bottom to the concrete floor. Nestle them close to each other to avoid gaps. I might even cover the windows if it gets real cold there. If not, then box them out (Literally) with cardboard box material stapled to the existing frames to form a well through the insulation for light and air.
I would definitely take a Wagner sprayer and do the joists overhead. I might even paint the floor a light color with a cheap concrete stain.
Insulate and seal that garage door.
And I might hang a plastic sheet and or insulation batts between the shop and laundry to conserve heat in the shop area.
They also sell batt insulation with a plastic cover that would work well, and allow you to easily take it with you when you leave.
Bill
Dan in Pasadena
Pasadena, CA
What everyone else said but I'll add this, give a quick sand and paint those window frames a light color using cheap but good paint from the mid-mix pile they have at every Home Depot and OSH. I'd suggest white but that's not on the mix-mix pile.
Personally I'd put a LOT of light in there. Those brick are gonna look great if the space is light.
S
saruken
Thanks for the great advice from everybody!
To address the temperature concerns, I live down in east Tennessee (and not in the mountains) so it never gets too cold. That said, temporary insulation and area heat would still be welcome during the winter months.
I like the idea of the white paint to help diffuse light everywhere, and the Craigslist bedroom furniture for temporary work surfaces is a great tip.
As for the visqueen over insulation, that sounds like a good fix, although I really like the look of the bare brick. Not sure what I'll do there.
The electrician is coming out in a couple weeks to look everything over and hopefully run some new lines for outlets, so I'll update then.
