Piper
HI everyone
Long time since I've posted here... been busy.. (aren't we all)
I have a mohawk system1 10,000 lb 2 post lift. I bought it new and it's worked flawlessly over the past 5 years in a hobby (but pretty regular) environment. Yesterday I went to lift a vehicle and the motor seemed to stall a bit, then the pump kicked in and the lift arms raised a bit.. then the breaker tripped. I reset, tried again.. same thing. I drained the ATF from it, gave it a good cleaning and some TLC, split the motor from the pump and confirmed that the motor would start and is functioning as expected. There was a bit of gunk in the ATF which I felt lead to the stall. Anyway, all back together and new fluid installed I thought I'd be back in business but it's still acting the same way. I think if anything a bit worse and again I wonder if this is due to some gunk sucked up into the hydraulic pump. Interestingly when I had the pump part off I could spin it with my hand but I'm unsure how easy that should be. Anyway, I didn't take the pump apart, I don't know what's inside, have no parts explosion diagram etc.
I'm wondering if ppl have opened up one of these types of hydraulic pumps and any advice etc. Of course this happens on Easter weekend, luckily the car that was on I managed to get back off...
thoughts or advice welcomed !
