Hows it going everyone. I got an air compressor that I have been having a problem with lately. It seems that an excessive amount of moisture is getting in the unloader valve and it never unloads by itself, I have to flip the lever manually every time it finishes unloading. When it unloads it spits a ton of moisture out, you can see in the picture the water droplets on the side of the compressor. Also, now when the compressor shuts off, the mag starter makes a horrible sound like it is rapidly switching on and off right before it reaches 175 psi, I took the cover off and let it cycle and is could see the sparks in there right before it shut off. This is a lefoo furnas style pressure switch with built in unloader. I have copper line running from the check valve which has a port for the unloader on it.
Can I install a moisture filter inline or something because it is really annoying, everytime the thing shuts off I got to walk over and unload it and I do painting and the paint booth is 75 feet away so I cant doo this much longer. Also, i think im going to burn up my contacts in the starter. Any advice. Thanks.
