Well I let it go 48 hours and it passed. I was nervous because I do not have a vapor barrier. I also have a high water table. About a week after I poured the floor I put a piece of OSB in the corner to put my lawn mower on just in case it leaked oil, I didn't want it to stain the new floor. I moved the OSB a couple weeks later and there was a dark spot where moisture obviously was stuck under the OSB. The dark spot has mostly faded, hopefully once I paint it won't be seen.
I bought the Rustoleum Professional epoxy in the 5 gallon bucket (not 5 gallons of paint). The label says it should cover 500 sq. ft. Is that fairly accuract or should I buy more? Is one coat enough?
Thanks, Jim
