molybdenum use in air tools
outdoorsman310
DE
would moly be useable in air tools to reduce wear in cases of water in the air supply or something? I just bought a FAR72C and am thinking of putting a small amount of mos2 additive in it and in my harbor freight air guns. i wonder if it would mess up the air vanes
Rider_996
This would be silly as it could more likely harm your tools than help them. Air tool oil in the air motor and grease in the head and your snap on air tools should last years even with daily use.
helterskelter
I don't think it'd harm your tools, but it would be a waste of molybdenum. Use air tool oil, it'll be fine. We use moly as a dry film lubricant in high temperature, high pressure applications. Your FAR72 is a much less demanding application :). Just some a little turbine whizzing around at just above room temperature. And I thought vanes were stationary and blades orbited. Air tool manufacturers need to get on the bandwagon.
d.mcfarland
Western PA
The viscosity of the MOS2 would be way to thick I'd think. The stuff has to be mixed with engine oil to have any benefits. With that said the 10 drops in a small bottle of air tool oil aren't even worth your time.
KinzeMech
I've always thought, if you're going to lubricate a machine with a non-spec'd lubricant, you ought know more about the machine, and the lubricant, than the guy who spec'd that lubricant in the first place.
Do you?
helterskelter
Do you?
It's an air ratchet man. Not exactly a precision piece of equipment. No need to talk down to him for asking.
KinzeMech
I'm not talking down to anyone. I'm just saying to use the right tool(lubricant, in this case) for the job. I hope I did not offend.
Haveblue
kansas
Im not sure if an additive will benefit a tool. I do ,however, agree with using air tool oil. I used to use whatever can of "lube" that was in the shop. I remember using PB blaster in my impact a couple of times in a pinch..I think the blaster is what ruined the inlet bushing in my impact. There are some guys that rebuild a lot of air tools here. Welcome to GJ op! :beer:
kythri
Lebanon, OR
Do you?
I'm not the OP, and I didn't take offense, but, this is an appeal to authority. Whoever spec'd the lubricant in the first place didn't spec out the best possible lubricant for the tool. They spec'd out the best lubricant that met a variety of specifications, not least of which would be price.
It's entirely possible that there's a better lubricant for things out there, but the cost/benefit ratio may not make it worth it to the manufacturer or most end-users.
Air tool oil being a common thing, it's entirely possible/probable that air tools today are designed around air tool oil as a lubricant, since that's what most people will have, and "better" lubricants never get tested.
Who here puts synthetic oil/lubricants in their vehicle? Is your vehicle spec'd to use synthetic? Or is it spec'd to use normal stuff? Should a person not consider "better" oil for their car because they're not an automotive engineer?
Ultimately, the guy thinks he may have a better solution that may make his stuff last longer/perform better. That he's asking questions about it indicates a desire to learn, which should be applauded. And, entirely understandable, when one buys expensive tools/toys.
O
outdoorsman310
DE
yeah these things last forever. 2 people in my shop have ones that are 20 years old and they still work great. i got a snapon socket set with it for "free"!!
