Momentary on switch for traffic light
Paulski
I have an old traffic light that I want to make turn on for ~20 sec when a push button is pressed-
The push button is mounted to the wall, its a cross walk button with a honeywell z4g1p05b
I have a controller to make the light show a pattern when turned on: https://www.amazon.com/dp/B09VLJ5779?tag=atomicindus08-20
I figured I would run a plug to the crosswalk button, that a cord up to the light, which will have the controller mounted inside it. But the cross walk button would need to be held down for the light to stay powered. Any ideas on something that will keep the light powered for a bit when the cross walk button is pressed?
RPH
Michigan Thumb
The one mentioned as a controller does have 39 sequences programmed. It uses solid state relays. 80-260 vac. Not a bad buy, needs a box around it.
