WI/MI Border
- Joined
- Jan 27, 2025
- Messages
- 196
First I want to mention that I want perimeter insulation on my monolithic slab under my 24'x 28' garage. The following is an attempt to create that insulated perimeter with very little wasted material. I don't mind the work to create these forms as I have quite a bit of winter left to build the forms as described below.
I've been looking at the "Mono Slab EZ Form" in their "Mini" foam form. Their EZ form is EPS foam, 12"x12" x 8' long, runs about $130 and is only available in quantities of 12 or 24 units. I need 14. The closest source for these is Toledo; about 20 hours round trip. Not gonna happen. Local vendors (90 miles away) have the 16" x 16" x 8' product in stock but for more money, 12 or 24 unit packages and the difficulty of dragging these home in two trips. A vendor suggested I buy the 16" and bury the bottom with 4" to get my 12" footing. That could work, but not for my purposes and budget.
So looking at the EZ Form it doesn't appear to be very technically difficult to build myself. My initial estimate is I can build one of these with 2" and 1 1/2" XPS rigid foam in 4x8 panels for under $40 each. Check my drawing and feel free to shoot holes in my plan. But please watch a video or two of their EZ Form before shooting the whole thing down. And no, I am not reinventing the wheel. I am attempting to build a knockoff of a proven product.
I would rip a 10" x 8' piece of 2" XPS for the vertical, slab side of the form. Another 2" x 18" x 8' piece would form the bottom which will provide additional perimeter insulation to slow frost from reaching the slab (I might go 24" if the cost isn't too high). Those will be laminated into an L shape. Additionally, inside of the L shape I would rip a 1 1/2" x 4.75" x 8' piece to support a 2x8 treated screed board. Another 10" will be laminated beside that one and then with whatever is left of the 2" or 1 1/2" would be used to further fill the L gap to form an angle toward the grade. I would backfill before the pour giving the forms more bracing; the forms will not be removed after the pour. Only the 2x8s will be pulled.
I'd reuse the 2x8 treated timber after the pour as the bottom base plate on top of two high concrete block. The void created pulling those 2x8s would then be filled with 1 1/2" foam (7 1/4" x 8'). The foam form would be staked into the ground with rebar and 2x form braces would be used to eliminate the chance of a blow out during the pour. Again, I would backfill the form before the pour.
I've worked with XPS quite a bit and feel confident it would hold the pour. The commercial ones are EPS, which I think has less strength than XPS.
