GT350RC
I'm in the process of buidling a 26x26x9 Garage, with a 12x26 storage area in the truss. The pad is monlithic, and is "exactly" 26' x 26', however, it was purposely sloped from back to front (for water runoff). In hindsite, since this is going to be a garage for summer toys (two Mustangs), the sloping was a bad idea.
Now, I need advice. When I built the walls, all of my studs are plumb to the pad, which basically makes the side walls a trapezoid. Sheathing was installed level, in order to fall on a stud. I'm going to be using vinyl siding.
Here's my dilema: What do I do with the siding? If I install it plumb, the area where the siding goes into the soffit will show the slope. If I install it along the slope - the bottom will look sloped.
Anyone run into this, and if so what's the solution?
