fred d
Ok posted a few days back about a compressor issue.
I removed the check valve in the top of the tank and it seemed to be clogged/stuck.
I cleaned it with brake cleaner and it seemed to move freely, so I reinstalled it and the compressor and it worked. with the tank empty it ran great and kicked off at 130lbs and on again at 100PSI. Opened a valve on the end of the hose, drained it down and it kicked on at 100 and off at 130psi
So today was working in the garage with air tools, it tried to kick on but oncenit got down low enough it just Bind/stallEd.
We kicked off the breaker and I pulled the bleed valve on the top. It made one revolution and bound up again.
so I held the bleed valve open and kicked the breaker on and once it was up to speed, I released the valve and it filled the tank.
So….thinking that replacing the valve is the next move
THOUGHTS?
THOUGHTS?
