CMcAllister
- Joined
- Aug 10, 2008
- Messages
- 24
Well, we've decided to not go with radiant floor heat for a number of reasons, including budget. Now we need to decide what we are going to use.
This is for a 40x52x12 pole building in southern PA, well insulated, worked in everyday and all day, and will also be air conditioned. I've had heat pumps, overhead radiant tube heaters,and forced hot air recommended with a variety of energy sources. At this point, I don't know what we are going to use, so I'm asking for suggestions for high efficiency, comfort and reliability HVAC options. What would you use and why?
Also, we are insulating the ceiling and walls, but would it be worth installing insulation under the concrete, even though we are not using in-floor radiant? Any experience or information on the benefits (or lack of) using insulation under the floor?
Thanks.
Thanks.
