Hey guy's,
I've read alot on the setups, I just had a few questions that I didn't see listed anywhere..
1. When running in floor heat on a slab on grade, with an electric water heater, why do you need an expansion tank? wouldn't the water heater do the same thing storing the hot water? If I look at the hot water system of the house, I don't see one.
2. In a closed system(with above mentioned hot water heater), do you necessarilly NEED the check valve? Hot water out the top of the tank and into the bottom of the tank. pump flows 1 way, I can't see the water stopping direction of flow. (It's not like I'm running a boiler where you need a mixing valve or zone to cool the water down a bit). If I look at the hot water system of the house, I don't see one.
3. is an Air scoop necessary? or is it just something to ease the mind? if the system is properly bled and pressurized, there shouldn't be any air in there.. and no leaks, is there another way for air to get in I'm not thinking of?
4. Ideally, we should be running moderate heat out of our heaters for the slab. What heat are you guys running at? What pressure are you running your systems?
I'm seeming to not be able to come to a decision on how I want to plumb it.. I guess I'm **** and want it to look clean. Can some of you post pics of the plumbing Jobs you've done? also note if it's single or multple Zones.. (I'm sure I'll be able to tell by looking ,but just curious).. mines a single zone 4 small loops.
Thanks guys
, I haven't seen any of these questions.. they are just done, I was more curious as to the why's. (I like understanding what I'm doing then just doing it cause thats the way it's done.
Thanks guys
