More on the Coes Key Model Wrenches
300man
Pawling, NY
I read several posts in a couple of old threads to do with the Key Model wrenches dating back 10 years or so using the search tool.
So figured time to start a new one.
From what I can tell doing research on the internet and finding old pictures, auction descriptions and advertisements there are at least 2 slightly different versions of the Key Model.
Both versions were offered in the 28" , 36", 48" and special order 72" lengths.
Seems the earliest version may or may not have had the Oct. 20, 1903 date on the upper jaw...and the stylish Key Model Trade Mark stamped in the main arm.
One documented difference of the earliest wrenches is that the tail of the adjuster where it extends beyond the strap was threaded and a hex nut was used as a stop to keep the adjuster captive. The other difference is the length of theses wrenches are closer to the actual advertised length.
The later key model wrenches had the stylish script Coes logo stamped on the strap. The adjuster where it passed through the strap was not threaded and had a plain sleeve or bushing that was pinned through the adjuster where it extended beyond the strap. These later versions in the 28" and 36" size were longer than originally advertised. The 28" actual size ranged from 31 to 32 inches and the 36" actual size was in the 38 to 39 1/2 inch range. I can't say exactly when the production changes were made but somewhere around 1920 would be a good estimate.
I recently found one of the later model 36" Coes Key Model Wrenches with the script logo on the strap and plain bushing adjuster keeper. It in fact measures 39 1/4 inches.
I have read that there was a book published by the man who tracked down one of two 72 inch models known. It may have these details about the Key Model wrenches included in the book?
crguy
SW Washington
I have this one that's 48": 888CF77D-DD1B-44D7-867B-1464862BC062_1_201_a.jpegE09E6E84-9933-4A30-9A06-0FFB5CDBD02A_1_201_a.jpeg
AntiqueBen
I bought a Coes "Key" model wrench today. The seller says it measures 31 1/2" overall. So I'm guessing it's the smallest 28" key wrench. I don't see these Coes Key wrenches pop up to often. They probably didn't mass produced these I suppose. Are these Key wrenches considered rare?
crguy
SW Washington
I would say they are scarce, not rare. The overall length seems to vary a little. I had one that was 33". Still have one that's 48".
AntiqueBen
I'm anxious to get this one & clean it up. I have a lot of big wrenches but not like this one. I'll have to keep an eye out for these. Doubt I'll ever see the 6fter. Datamp said as of 2015 there were only 2 known to exist.
AntiqueBen
My 28" Coes Key Wrench showed up yesterday. It actually measures 31" overall. These Key wrenches truly are indestructible. Weighs a ton. This one also has a "1" stamped on the shaft. Not sure the meaning of that mark. In case some people don't realize, these wrenches have a special way to adjust them.
If the wrench is closed all the way, you can't just screw it down all the way open. The screw adjustment only goes so far. There are two notches on the shaft, a low & a high notch. If it's in the top notch, you can screw it closed. If it's in the bottom notch, you can screw it all the way open. And of course the lever or "Key" on the back side of the shaft you can push up to lock the wrench in any given position.
This size Key wrench seems like it would be the most practical to use of all the Key wrenches. The other sizes I know would be even heavier. Although you have to use whatever fits the nuts & bolts your working with, so they all serve their purpose. The Coes Key Wrench truly is unique compared to any other monkey wrench ever made.
AntiqueBen
I have a 28" Coes Key Wrench & I just acquired a 36" too. So I'm now looking for a 4fter to complete my collection. I'm sure I'll never find a 6fter & if I did I'm sure it would command an outrageous price. Plus my wife would think I lost my marbles if I bought a 6ft wrench. I'm just curious where you found your 4fter? I've never seen these in the wild & almost never online. I'm guessing they didn't produce a ton of these as the demand for a wrench this size was probably low. Do you know any info on Coes production of these Key wrenches as far as quantities?
AntiqueBen
Do you know the name of the book of the man who hunted down the 6ft wrench?
crguy
SW Washington
I bought the 4 footer from another collector. I already had a 33" I had found locally. No idea on production numbers. I also have a similar 44" key lock wrench with no markings I could see. It was heavily rust pitted. Could have been a one off blacksmith made, would like to know. It was found in an old riverbed area, may have been lost off a dredge or something. Since I got the 48" Coes, I would sell this one. 07C4DD23-E071-41D9-9E14-1978A82089F7_1_201_a.jpeg
AntiqueBen
I bought the 4 footer from another collector. I already had a 33" I had found locally. No idea on production numbers. I also have a similar 44" key lock wrench with no markings I could see. I was heavily rust pitted. Could have been a one off blacksmith made, would like to know. It was found in an old riverbed area, may have been lost off a dredge or something. Since I got the 48" Coes, I would sell this one. 07C4DD23-E071-41D9-9E14-1978A82089F7_1_201_a.jpeg
My 28" Key Wrench is actually 31-1/4" overall. Crazy how there's so many variations in overall length. That's an interesting 44" example. It looks well made. It's a shame any markings it may have had are gone. It doesn't look Coes to me though.
It appears that the Coes Key Wrench production stopped in 1928 when Bemis & Call bought out Coes. I can't find any ads for this wrench after 1927. You would think you would see more of these out there, but they seem to be pretty scarce. Hard to say how many got scrapped after getting old, bent & rusty because they weighed so much.
AntiqueBen
The Coes 3ft Key Wrench showed up today. It actually measures 39-1/2" overall. Definitely a beast. This one is stamped with the Coes in cursive script.
AntiqueBen
I've looked at a lot of pics online of different Coes Key Wrenches. I've noticed they are sometimes stamped differently. Most all have the patent date & Made By Coes Wrench Company on the upper jaw. In addition to that some have the Key Model (with key) stamp on the handle....and some don't. I haven't seen any others yet that is triple stamped like mine. It has both of the above mentioned stampings in addition to the cursive Coes on the strap. Just wandering if anyone else has noticed this & if it makes a difference in the collectible aspect of the wrench?
AntiqueBen
I believe I found the book that has the story about the Coes 6ft Key Wrench. It's called "The Brother Coes and Their Wrench Legacy of Wrenches" written by author Herbert E. Page. It's actually an 86 page book about the entire history of Coes with pictured examples of every wrench that Coes ever made. I understand it has a whole section on the Key Wrenches. I also found the website where you can purchase this book for $45 HERE
The forward is even written by Loring Coes III. It looks like an awesome Coes resource with tons of specific info that can't be found anywhere else. Below are pics of book cover & ordering information.
