ok, so I'm getting the wiring done in the garage. all is good.. here's the scenario..
from house 200Amp Main to 100Amp sub panel in the garage..
wired wtih #3 copper burried in PVC
got my lights circuit up the other day, works fine
tonight I got my 1st rec circuit up
I also ran 40Amp to a sub Panel that is in a shed(attached to the garage)
History on the shed, when I bought the house, that's all was here was the shed. He was running 40 Amp from the house to an Old Squard D subpanel in shed.
I basically did the same thing, but from the sub panel in the garage..
All my lights, and recepticals work in the shed now that I have 40 Amp running to it, however, there is a construction heater plugged on a 15 Amp 220v that doesn't work. the breaker doesn't trip, it just doesn't run.. it ran before I disconnected the power to build the garage.. Any Ideas?
the neutral bus on the Sub Panel in the garage is NOT grounded with the screw.. I took it out as it is a sub panel.. it is being grounded by the main in the house.. the Sub Panel inthe shed has it's own ground in the floor.. Think perhaps that it doesn't have a good enough ground? the breaker for the 15Amp 220V that's running the heater looks different. I'll have to double chcek again in the AM..
Any input to check would be great.. thanks guys..
Unless it isn't the proper breaker for the panel I'm not sure how a double couldn't get one of each leg. Good to hear you figured it out.
