Mortising a door striker plate on vinyl?
90zcar
Has anyone mortised a striker plate on a vinyl/fiberglass door?
I have a dual shop door setup where the one door is stationary unless you undo the dead latches at the top and bottom
Anyways I put new Schlage lock and knob setups on and it seems like I need to mortise the striker plate into the door as it is tighy when I close it with it on. Shuts fine without it.
I'm assuming the stationary doors edge is vinyl.
Can you hit this with a chisel like a normal wood door?
Here's where it binds up
OKDave
Edmond Oklahoma
this cheesy kit, actually has a cool little template to rout out for the plate depth. I wish I could find a heavy duty version. It might be worth it for your one time job thou. You screw the template guide into the screw holes, and it allows you use a mini router thing with any drill, you follow the guide and it routes out the outline and then you just chisel out a few small sections.
Dave
https://www.amazon.com/dp/B000EEX5UY/?tag=atomicindus08-20
90zcar
Dave
I think that would work well for the knob latch plate but not the striker
tcianci
Walpole, Ma
If the material you need to mortise is indeed vinyl, it will cut just fine with a sharp wood chisel. if you need to create a radiused corner to match the striker, use a suitable Forstner bit carefully.
drmarkr
Tucson
You should be able to cut the vinyl with a chisel, and then use a Dremel to carefully route the pattern? Or even use a cutoff wheel in the Dremel, since you'll have it out, to cut the straight lines in the vinyl and a diamond bit to do the radius's.
90zcar
Went to lowes and ended up getting a dremel router attachment for 17 bucks.
