Boringgeoff
I'm really buoyed by the response to my query about a Hol-Set tool so I'm going to have look at another tool.
This is a Frank Mossberg No 611 which I think is a wire twister for lock-wiring transmission and differential bolts, though I have no proof of that and a lot of people have looked at it over the past few years.
It has a locking arm that cams over when there is a piece of wire inserted in the jaw. The plate on the front of the jaw can be loosened and turned 90 deg to use a different sized piece of wire. On the back of the tool is "Pat Pending" the handle says "Frank Mossberg Co Attelboro Mass. USA". On the top of the head is "Patented March 30- 20" this refers to the patent of Walter Tuttle assigned to F. Mossberg (US1335409) for the head construction.
Photo No 005 shows the head with a screw holding it on which is not part of the patent. Photo No 003 shows wear on the frame at the rear of the handle, both these photos prove that the tool has spent its life being pulled back as you would when twisting wire tight, to the extent that the head has come adrift and had to be repaired.
I'm hoping you folk here can give me a definite purpose for this tool.
Cheers,
Geoff.
Cheers,
Geoff.
