Most compact automatic cord reel?
tarbellb
Oregon
Hoping to get some help finding a
_ compact
_ automatic
_ only need 2 amps
_ 6ft-12ft cord length (longer is fine)
looking to mount one of these into a cabinet for 2 uses a week so it doesn't need to super robust.
I've looked in the usual places, no luck for something that checks all the boxes.
- thinking something along the lines of a hair dryer or curling iron that has these built in? or?
Thx!
T
tarbellb
Oregon
I'm trying to avoid ripping apart a item to scavenge the cord reel.... it's my backup plan tho.
GeoBruin
TROND Retractable Extension Cord Power Strip - Travel Power Strip with 3 AC Outlets 3 USB Ports (2 USB C), Ultra Thin Flat Plug 5ft, Cruise Ship Essentials, for Home Hotel Dorm Room, Black https://www.amazon.com/dp/B0CGZJSVVJ?tag=atomicindus08-20
Auto Retractable Cord Power Strip,Bototek 6 Outlets with 3 USB Ports (1 USB C), Auto Retractable 6 ft Extension Cord, Flat Plug, Portable Travel Power Strip for Cruise Ship Home Office Dorm Room https://www.amazon.com/dp/B0D3BVSSYZ?tag=atomicindus08-20
Really small but not great reviews on the retracting mechanism.
Nexhi® Zip-PWR-EX1 Retractable AC Power Extension Cord (5 feet, Black) https://www.amazon.com/dp/B01BPT7BGK?tag=atomicindus08-20
Looks legit, maybe harder to get.
I have one like this for an aux cable. It is kinda finicky, you have to keep both sides flat and even as it rolls up, else it jams. This one “ rolls to the center”, which might be a pain depending on your application. I think mounting the reel, and pulling out the socket end would be best, but you need to make that call.
GeoBruin
Mountable.
T
tarbellb
Oregon
Funny how Amazon and others still feel antiquated when it comes to search algorithms
If I simply used "travel" in my original search quest I would have likely found something similar to what @GeoBruin (Thanks!) found
I did try plenty of other descriptors, none netted these more promising products???
Either way this is looking good.
My application requires a female plug at the end and preferably a short pigtail male at the reel end. Much like a shop reel. I will modify as necessary if needed.
GeoBruin
The Amazon search algorithm is terrible. I use Google and limit the results to Amazon if I want. Travel did yield some promising results.
RMERR
Northern CA
Sears had a vintage small retractable reel. They're still quite available on Ebay. Another vintage reel (with slightly better mounting braket) is Cordomatic, also on Ebay sometimes. The reel itself is only about 7-8 inches in diam. I used a pair of these on some light stands I built. These have work lights on the end, easily replaced with a plug.
T
tarbellb
Oregon
I did come across both of those reels, the Cordomatic looks solid. The Craftsman model looks ok but commands $50+ a piece
Thanks but I'm looking for a much smaller package
