Most durable/best clean-ability flooring options
Jarred767
Bend, Oregon
Hey everyone! I'm a mobile detailer, and will be leasing my first shop sometime soon and starting to do some research in different areas. I don't have the specifics on a location yet, but I do know I'll almost definitely be upgrading the flooring (this is all pretty new to me BTW)
I'll need something that is durable and relatively easy to clean. It gets well below freezing here in the winter and can easily reach 100 in the summer so I want to have a bay for washing indoors. They use a crushed volcanic lava rock on the roads in the winter, so wheels wells are full of the stuff (which I'll be washing off and will end up of the floors) hence the need for easy clean up. Neglected wheels usually need some degree of an acid cleaner, so that's why I need it to be as durable as possible. I plan to market the business to higher-end clientele, so the overall look is also of somewhat importance.
Any suggestions or combo of suggestions would be great. I'm sure I'll have more questions as the process continues to unfold over the next few months. Thanks
J
Jarred767
Bend, Oregon
Thanks! That's kind of the direction I was expecting to hear - something epoxy. I really like the look of Racedeck, but in assuming the clean-ability would be a lot lower than epoxy?
iskuta
Metro Detroit
I would check with your local Sherwin wiliams commercial store or PPG. They will point you in the right direction for what epoxy system is needed, the cost, and contractor that do it. I know in my area different epoxy jobs range from $3-$15 or more depending on the system used and the prep work involved.
Garage Flooring
Grand Junction, CO
Rust Bullet will be budget friendly and check out the abrasion, heat and chemical resistance. Give me a call and we can get you samples of both epoxy and Rust Bullet and you can play.
LegacyIndustrial
deerfield, IL
Correct. Another thing to consider is you might have clients visit. You want some "pop" for your shop!
J
Jarred767
Bend, Oregon
Yeah, I was thinking maybe a Racedeck for the small office/"waiting" room and then some sort of epoxy for the actual garage? I take a lot of pictures for website/social media stuff, so definitely a nice bright and clean workspace will be important.
I might just just have to hit you up for some samples Justin once I get a place nailed down. I will be doing plenty of research and would love a great option as I plan to use this space for quite some time.
Garage Flooring
Grand Junction, CO
Happy to help. We could work with you on all the products you need and maybe a discount for a few mentions here and there 😄
monkeyjuice5150
I had racedeck, they look cool and all, but didn't really stand up after 2 years.
Then I had epoxy, looked great for a year but it wears and tear so fast.
All that money dumped into the floor, I could have just done it right the 1st time and save money. If you want it to look professional, long lasting then the 2, then go with polish concrete with a stain. More elegant and professional and wayyyyyy easier to clean.
LegacyIndustrial
deerfield, IL
Monkey: That is a great option. However, be careful of how much betterment you bestow on your landlord if a leased/rented space and polished floors are slippery when wet with no ability to add anti-skid.
The trick is matching the traffic/use to the system. Many to choose from, talk to folks who really use the stuff, not just sell it. :beer:
J
Jarred767
Bend, Oregon
Thanks again for the additional info guys. As much as I like the look of Racedeck, the more I read about it, the less I feel like it's the best fit for my specific situation. I really like the sounds of some sort of epoxy coating with anti-slip mixed in to keep it from getting slippery when washing.
Another option I was thinking about was simple slotted rubber matts in the wash bay on top of an epoxy flooring to add traction in just that area where it would be needed. I would have to remove and clean the matts every so often, but it's not like I wouldn't have cleaners and pressure washers at my disposal - it is more work though... Just trying to make sure I would cover all options.
I'm meeting with my leasing agent on Wednesday to go over a space that I'm getting excited about. Hopefully some time soon I'll be able to start putting actionable steps in order instead of simply researching.
Again, any other thoughts are suggestions are more than welcomed.
