ddawg16
Another vote for that bad boy
A second set of hands to help when its tough to do something solo. My kids 4 & 5 yrs old are not quite there yet, in a few years they will be invaluable in the once in a while I need their help.
Often my brain.
)BFH! When you need that big hammer you are glad you have one (rusted on brake rotor).
1-1/4” deep socket for the crank bolt on mopar engines. I don’t use it often, but I’m glad I have it.![]()
Intriguing idea for a discussion from Adam. What's your least used, but most important tool?
Mine is an obvious one. I don't use a torque wrench all that often, but when I truly need it, it's for something damned important...
Easy one for me. FAST ACCESS TO 911. Only needed once (so far, and thats enough), but lets put it this way. I sure do have a shiny white knee cap! And zero probs bleeding! Volunteer Fire fighters/Medic here in 5 minutes! Love our little rural community....and they like my shop too!
A snap on TM84. They say it's for carbs, but I pull it out whenever I need to remove a band clamp in a tough spot. Perfect design for not slipping off the screw the with that shrouded flat blade.
Fire extinguisher.
Smoke/CO detector.
Plunger.
My *****.
Years ago I bought a tool that was advertised as a carb cleaning tool for motorcycles, I learned recently that it's a torch tip cleaning set. But, hey, what ever it works on!Small torch tip cleaning set. Every small engine that somebody throws away or sells for dirt cheap because they cant get it to run is usually fixed by a thorough cleaning of the carb, and these work great for getting in the small passages.
Often my brain.
One of these. It hardly ever get's used but when it does it saves my bacon.
I have an Earthquake one man auger. It gets used every few years or so. When it comes out of the shed for use it certainly makes my life better. I can't imagine how long it would take to dig a hole I auger handles deep with it using a regular posthole digger...Let alone 6 or more. Makes me hurt thinking about it.
You must not have clay. I rented a similar tool when I built a fence for my yard. I could dig the holes using a shovel, digging bar, and two sizes of clam shell post hole diggers in half the time as using the auger, and less lifting, because the auger had to come out of the whole every couple of inches, and the clam shell to pull out the loosened soil. The amount of torque they can supply is limited by the expected strength of the operator, because the operator has to resist it. That's not enough to deal with tough clay, rocks, or roots. In sand, they're probably okay. The ones that mount to a tractor or skid steer are great, because the tractor is heavy enough they can use real torque.
