most useless tool
tylerae40
western Australia
LOL, i was given one of these by the missus, and it worked well for doing wing nuts on coffee tables and old chev truck seats but not much else.
Any really cheap tools are ****- was given a "roadside tool kit" for xmas, used it once pulling parts of a wreck- snapped the pliers, bent the cresent- wouldn't open/close, left it in the wreck, it was gone 1/2hr later when i got back with my box.
gmc eletric saw- wouldn't cut throught a door pillar+ snapped the blades+ then couldn't get blades for it = binned
Garys Garage
il
Air powered scraper. Bought it off one of the tool trucks, SO I think. Vibrated like crazy but would change speeds and wasnt any faster than razor blade scraper. Gave it away.
Miter Wrench
Colorado
My first purchase on ebay was a cheapo paint sprayer. It felt good to throw it away.
Sounds like we'd better keep our 16mm sockets/wrenches...
Bobby B.
Southern California
I don't know what it's official name is, but I received this huge "ratchet" with a red-tipped t-handle at the top. Supposedly it's so you can tighten the socket at a 90-degree angle in a place where you couldn't turn a socket or wrench? But the thing is so F'n big and pointless that I can't see where it could be useful.
It's never left the old toolbox I got as a kid.
illmatyk
Yigo, Guam
Husky tire pressure gauge/inflator, thing broke after 2 weeks.
Craftsman 1/2 impact gun, broke after a few months and Kmart didn't wanna honor my warranty even tho it says 1 year on the box......
Aberdale
+1 on the Craftsman Robogrip pliers. (Should have just called them Robo-rounders.)
Just about all easy-outs. (Less than 50-50 chance of successful extraction.)
Flat ratcheting wrenches that need to be flipped over to reverse. (Heads are too big to get into tight clearances, being flat it's too easy to skin knuckles.)
Dale
gkring
Keller, Texas
1/4" drive Clutch head screwdriver socket.
Useless for me. Ive never seen or known anyone else who has seen a clutch head screw.
Holley carbs with metering plates. I swapped and drilled plates so much on my old Mopar 6 pack setup I bought the clutch driver as I was tired of trying to make that small tip screwdriver work.
Mu useless tools are cheap ease outs, spend an hour drilling holes just to have the ease out polish it up for you. they should come with a set of helicoils since that is what you are going to have to use by the time you are done. Since then I have bought a quality set.
jerryW
Phx AZ
I used to have one of those when I was younger and dumber. It was called the "Sidewinder". What a piece of ****!
jerry
nato
Northeast Ohio
lilredex
Toronto
probably a snap on speed wrench. i had just got a shop job when i was 17and the snap on truck came by. i bought the first shiny thing i saw lol.. i think ive used it once or twice in 14 years lol. its a bit rusty now from lack of use
I regularly use one of those (3/8" drive) to drive wood screws (Especially ROBERTSON type) and various nuts (using a deep socket). Years ago while working in an engine rebuild plant, we used them to tighten up pan bolts, timing cover bolts, front mounting plate bolts, etc. They were the cat's meow at that time, today they would have used something else I guess.
lilredex
Toronto
Dale
Get some LH drill bits to use once you have a pilot hole drilled, most times the broken bolt turns right out. Using easy outs sucessfully takes practice, something like using handtaps. With a bit of experience you get to anticipate when it is time to quit (before it breaks off).
I got a $2 flat ratcheting 9/16" wrench out of Princess Auto's junk box that gets regular use on my exhaust systems. Fits in most places that a socket/ratchet setup won't. Best $2 investment ever!!
lilredex
Toronto
I would have to say one of those automated center punches that you press down on, took more effort on my part to put my hole body weight into pressing it then just getting a hammer.
Back off the spring tension a bit, they're only designed for layout work to define the point easier. Come back in with a regular punch and hammer if that spot will be drilled. I prefer mine as it allows me to get the hole located more accurately.......no longer have the vision of a seven year old!!
lilredex
Toronto
This was the style i had, It was really hard to press.
Any one mind shareing what brands they have that work well for them?
Also sorry about the thread hijacking.
Looks just like the one I use, and is adjustable. Mine came from BusyBee Tools and is likely the same one.
lilredex
Toronto
I love the dremel. I've used it with one of those fiber backed cut off wheels to cleanly and precisely cut out sheetmetal on my cars in areas where a larger cutoff wheel wont fit.
Also good for cutting off the heads of bolts (in awkward places) that hardly have a head left on them (rusted round).
matthew
The worst ones I’ve experienced:
A pair of old wire strippers my grandmother cleaned out of a drawer at her house. Don’t know where they came from since gramps always bought good tools, or perhaps it’s just that the design of these have improved over the years. Anyways, I never used them because I had a better pair, but I don’t like throwing away tools. So after years of being in my truck and then the bottom of my toolbox, I tried them – horrible. The cutters wouldn’t cut through 18ga stranded copper, and if you tried stripping the insulation the wire just wanted to jam between the two halves of the tool. Imagine like cheap scissors. Might not help that I’m left handed, but this is one of the few occasions I have garbaged a tool.
I was given a bit-type screwdriver set when I was about 13 or 14. I think it was a bonus item my Dad had picked up for free, and gave to me. The kit had two separate screwdrivers in it, oddly enough one was a ratcheting screwdriver with hex bits, and one was a fixed type with collet bits. The one with the collet-type bits is actually decent, but the ratcheting driver is horrible. It has several problems:
1) Just 10 teeth in the ratcheting mechanism is nowhere near enough for any tool, but especially not for a screwdriver.
2) The ratchet mechanism is below the handle, not built into it. So with a hollow handle, the balance feels wrong, even if the handle is filled with bits.
3) The switch for forward/locked/reverse tends to shift on its own.
4) The cover on the end of the ratcheting section tends to unscrew itself.
5) There is a flex joint between the ratchet mechanism and the handle, the idea being that you could use it as a regular screwdriver, or turn the handle by 45 or 90 degrees so it’s more like a pistol-grip screwdriver. Apart from the shape of the handle being wrong for this, the lock to keep it at 0 / 45 / 90 degrees tended to loosen itself off.
I kept the bits and sockets that went with it, but use them on a different screwdriver handle.
My sister-in-law had an experience that probably tops them all. She was helping someone build a fence, and they had bought some extra claw hammers. So they went out, and started pounding, and on the first nail the head of the hammer broke off. Then they tried the next hammer, and broke the claw on it immediately. The guy had bought stuff from a dollar store, and claimed “it was a perfectly good hammer.” Yeah, right. My sister-in-law was not at all amused. She’s not a tool person, but does know you get what you pay for.
Ser50
Vancity
a master slim-jim kit.
i mean, its not useless. its really nice, but for 100 bucks, ive used it ONCE.
Ser50
Vancity
16mm and other strange sizes are common on metric engine cap screws (detroit/cummins) where the head size is'nt dependent on the bolt shank as found in imperial.
selohssa
Edmonton Alberta Canada
I bought a battery operated Dremel. The battery would not hold a charge long enough to cut off a sprinkler escutcheon. It did have a nice bag though.
I love my battery operated dremel for windshield chip repairs.
As for useless tools, a lot of blue point tools ****. Their locking pliers and Snap On spray guns are coated with paint. The first time that you get solvent on them, they look like ***.
The Blue Point auto center punch is a pile-o-****, I thought that I just got a bad one and bought another. Both ****.
The best auto center punch that I have used is the Starret one by a long shot.
Az Scooter
This little beauty my wife bought me.
y20dth
Antwerp, Belgium
This caliper, 7 feet long!!!...although it was the most useless (because it needed three people to use it...LOL) it was also the coolest!!! I also got the Granite surface plate it is sitting on.
I think this should be in the WTF-thread ! :lol_hitti
WTF do you use that for ?? Enlighten me !
pedro1990
1. prazi putter remover for electric drill-impossible, period.
2. snap ring pliers from ace hardware-tips spring around when used
crewchief888
NW indiana
hmmm
i cant really think of anything that i bought thats useless.. :headscrat
just about everything i have i bought for a reason, some were only used 1 or 2 times.
the wife dont buy me much, she usally asks what i want/need, and tells me to go get it.
she did buy me a skull welding hood about 10 years ago, and was surprised last summer when i was still using it. "I'm surprised you didnt throw that away" i go through a LOT of pocket size LED flashlights, after they get dropped in oil or fuel they usally dont work, she keeps me supplied with them :)
:beer:
thump186
maine
18 volt cordless Ryobi reciprocating saw. hold charge bout 5 minutes. Also the cheap cordless drills my farther in law finds at yard sales and every where.
