Motion sensor for garage light?
rodm1
What are good motion sensors for turning on my garage lights in a unheated garage? I think a PIR motion sensor is what I'm looking for any suggestions?
driftpin
The Liftmaster 8500 jackshaft garage door opener comes with a two-bulb wireless garage light. Of course it needs a 120 V hard-wire, but it wirelessly-communicates with the Liftmaster 888 LM https://www.liftmaster.com/for-homes/accessories/control-panels/model-888lm wall-mount, which offers many other features, including suitability for monitoring your installation on the internet (additional router interface required).
I understand you're probably looking for an infrared sensor as a stand-alone addition to activate your light, but if you are planning to update to a new door opener, the Liftnmaster 8500 is one to consider, not as-easy to defeat by a burglar as ones mounted in the middle of the door.
Here are choices from the Big White & Orange Box store: https://www.homedepot.com/s/lutron%20motion%20detector?NCNI-5 A variety of features, including three-way switches.
PhysicsDude
Dallas, TX
Most obvious solution is an occupancy sensor wall switch such as this one:
https://www.homedepot.com/p/Leviton...upancy-Detector-White-R02-IPS02-1LW/203826482
Its limited to 300 watts, so you might need a more expensive one depending on how many lights you have. Make sure you get one that specifically says its compatible with LED and CFL. That also typically means it requires a ground connection, which not all light boxes will have, so make sure to check if yours does.
In my garage I used a motion sensor from an older outdoor fixture I had laying around. It works really well. Its something like this:
https://www.homedepot.com/p/Defiant...-Outdoor-Motion-Sensor-DF-5716-BK-A/203739884
Again, check the specs, many motion sensors are only rated for 150-300 watts, or are not compatible with LED/CFL.
I've had good luck with motion sensors in unheated garages, but they will usually be "triggered" when the garage door opens and changes the ambient light level, which I think is a plus.
polizei1
Cinci, OH
I can't tell you how it works yet, because my home is still being constructed...but I'm going to use a Wattstopper DT-355. The 355 is specific for line voltage, the 305 is for low voltage. It's a duel technology (PIR/Ultrasonic) that will be used with two Liftmaster 8500's, as I did NOT want to use the factory bubble light.
R
rodm1
That is a nice unit but expensive! I'm going to look into this more any other suggestions?
CJ7VFR
Central New Jersey
How much do you want to spend on this?
Is the motion sensor just for lighting up the garage while you are going in and out quick to get stuff or put the trash out?
Or do you want all your garage lights on a motion sensor so the whole place lights up while you are working?
Jim
dogdog
Don't you want those occupancy sensor instead of motion sensors ? (even though it is the same)
cybrdyke
USA
images
Just screw in the lightbulb with the sensor built in.
Also available in a PAR30 flood light or a BR30 downlight.
Sengled SmartSense.
Get 'em on Amazon.
CD
