thool
I have a loft in a section of my garage, where I keep my tool chest. Problem is, it is kind of dark under there, and most available light is blocked by my body, so it is hard to make out socket and wrench sizes.
I've thought of adding lighting, like a couple small clamp lights, triggered by a motion sensor. So the order would be something like outlet, to extension cord, to sensor switch, then the lamps. I'd rather not hard wire anything.
Attached is a pic of the space in my garage. You can see the receptacle box and joists for the loft. I can put the sensor under the header, and the lamps a little further back.
Any advice on the type of sensor I need, or the lights that would be best for this? Thanks.
