Senorpablo
A post about brake bleeder screws reminded me of a great tool I purchased and used not too long ago.
I've done many brake jobs, and bleeding always seems to be more art than science. I find the two person bleeding procedure to be a bit lacking in terms of confidence of being well done. Often times, there's no one around to help anyway.
There must be a gizmo to bleed brakes. I have a Mightyvac vacuum pump, but had terrible luck using it for brake bleeding. Vacuum systems require the bleeder screws be perfectly sealed. The Motive Products power bleeder is a pressure system, and seemed to be well regarded on the internet, and the price seemed right.
http://www.motiveproducts.com/02bleeders.html
The unit was well made and came with everything needed for my application. They sell an assortment of caps to fit different vehicles, as well as some universal adapters. I've read reports of the universal adapters being a bit tricky sometimes--there are sealing surfaces and hold down chains. My Subaru has a fairly common screw on cap, and Motive makes a direct fit part for it.
The power bleeder works as follows: Fill the power bleeder reservoir with brake fluid and close the top. Remove the cap to your vehicle's master cylinder reservoir, and screw on the power bleeder cap. Pressurize the bleeder using the built in pump, and pressure gauge. In the proper order for your vehicle, and using the familiar clear tubing over the bleeder screw into container, bleed each corner.
The flow of fluid isn't terribly high--it took under a minute at each wheel to fully flush the line with new, clear fluid from the master cylinder. The large reservoir on the power bleeder allowed me to fully flush my car without refilling.
The power bleeder really makes bleeding/flushing brakes a smooth and satisfying operation. If you're not satisfied with your brake bleeding method, I would definitely recommend one.
