_brian_
I have a motive brake bleeder that I have often just used the universal adapter for. Recently, I decided I should really start using the proper adapters, when it is something I will use more than once in my estimation.
For those who do not know, this is the site for the product line: https://www.motiveproducts.com/
My questions is mostly for those who have used one of their pressure bleeders, although the opinion of anyone is welcome as there is also that side of the opinion. In my case, I Am looking at the adapter for late model GM, part number 1108/1118. The difference, in general, is the first is a plastic cap and the second an aluminum cap.
1108: https://www.amazon.com/dp/B000TYE16G/
1118: https://www.amazon.com/dp/B00YS8JW54/
At least on Amazon the price difference is ~$10. My question is simple, is the difference worth $10? One side of logic tells me that aluminum is more durable than plastic. The other side tells me that the factory cap is plastic and so it what it mounts to, so aluminum is more prone to cause other damage as it will be tougher than what it mounts to. I do not have either adapter in my hands, so I cannot address some simple logic like build construction.... so I cannot speak directly to build quality. However, one advantage I often hear is that the aluminum adapter creates a better seal, causing less leaks. However, again, the factory cap is plastic, so if the adapter is made of the same quality at least as the factory cap is, leaks should be of no concern.
The difference is only $10, so we are not talking a large difference here. But when getting more than one adapter, that $10 can add up as you add more.
EDIT: apparently there is no way to remove the web spam that is auto inserted placing tags on external links to Amazon, I tried
