Plastikosmd
- Joined
- Nov 17, 2016
- Messages
- 1,254
make sure it isnt an abrasive brushclean it up with a brush and see how much is left
at home, I used anything I can find, like a 1000 grit sand paper and a wire brush. It’s already arc and pitted, that is where you are at, needing to fix to hope it last a bit longer cause those platinum and gold plated pieces are just too dam expensive or I am too dam cheap. At the expense of my own risk of cause. Use your best judgement what you can handle and do.make sure it isnt an abrasive brush
not a good idea....I used anything I can find, like a 1000 grit sand paper and a wire brush.
For work yes I agree, for home…. Dependents on how much cost and your comfort level.not a good idea....
Arguably, gold is the best conductor. I used to coat the contacts in the rheostat on my Lab (think, sewing machine) belt engine in the dental lab with 450 fine gold solder, seemed to hold up well. 450 fine is not pure gold and has a lower melting point than pure gold.
Silver plate, at least.We were always told that the contacts in the 480v breakers we occasionally scrapped were silver. I guess we never got around to PMI nuking the parts to see what they actually were.
