Hi all-
I've been lurking on here for quite some time now, and have been fairly active on the HAMB, but haven't really needed any garage advice until now. So here's the deal, I scored a free quincy 216-L air compressor w/ 60 gal tank, only bummer was that it was set up for 3 phase power. No biggie, I craigslisted a 3 hp single phase Baldor motor (L3609T) for it, and a single phase NEMA 1 motor starter w/ overload relay. I think my motor is having issues, here's what it's doing:
Motor seems to start up and run just fine. After the motor is shut off, it will freewheel for a little while and then make a funny noise/vibration and the motor will slow down suddenly. The issue is almost undetectable with a bare shaft, a little worse with just the sheave (pulley) installed, and sounds terrible when it's belted up to the compressor. While hooked up to the compressor it will nearly seize the shaft in it's tracks after turning the switch off. Has anyone had this happen before?
I had a motor rebuilding shop look at it (changed out the stationary switch contacts, replaced bearings, basic maintenance stuff) with no change whatsoever. I have never heard another motor make a noise like this, but just to make sure, i hopped on you tube (laugh if you will....)and listened to a bunch of big air compressors, and NONE made any noises like this.
HELP!
HELP!
