Motor Question
JG Owens
Lehigh Valley, PA
I'm installing the motor that I just put fresh wires on and it's a little crowded coming out from under the cover plate. There's an open hole in the motor casing and I'm wondering if they make a right angle fitting similar to the ones used in conduits?
11b30b4
GA
That opening is actually a conduit port. Often romex or some other flexible conduit is run through it. Measure it and you should be able to locate a 90 degree or elbow for it at the local box store.
