Motorcycle lexan visor ****** repair questions.
TT_Vert
Wauconda, IL.
I have a BILT helmet (Made for cycle gear here in Illinois) that is about 3 years old. The visor is no longer obtainable (New or used) and this helmet has sentimental value to me and I'd like to continue using it. One of the lexan ******* that rides in a detent to hold the visor up has partially broken. I have some material there so I was considering finding a polycarbonate (lexan) epoxy to build up the ****** and sand it to size. I was also considering 3D printing a mold and not having to do that at all. I was wondering what you guys do to repair lexan/polycarbonate?
I am attaching a pic of the damaged side. Despite the appearance in this pic, there is enough base material that I will be able to bond to if I find a well adhering epoxy. I don't have any spare lexan to solvent weld this but any info to that effect is also helpful. Failing all this I could 3D print a new ******, drill and countersink for a small stainless screw into it but that would be my last resort.
Thanks much,
Dave
gorilla
Do you have a Tap Plastics in your area? They have a solvent cement that works for Lexan and may have small bits of Lexan avalable.
Bigblue&Goldie
How much is a used helmet (if you can find one)? The Bilt stuff isn't very expensive new relative to other brands, so maybe this would be a good avenue.
Gutman
ENC
TAP Plastic will ship the solvent and their prices are reasonable.
They've also got good guidance on a lot of plastics and how to fabricate stuff.
Check them out online or call them.
T
TT_Vert
Wauconda, IL.
I guess my question would be how to apply lexan to the ****** and fuse it. I was hoping to use the solvent to melt the lexan and put it on the ******/form. Then sand. But what I think i'd have to do is sand half the ****** flat and then fuse a piece to it then sand it round.
Dave
whateg01
doo dah, kansas, usa
...Tap Plastics in your area... have a solvent cement that works for Lexan and may have small bits of Lexan avalable.
Dave
I think a reasonable answer was already posted.
cleaner
At home
Can you use the remaining material to create a boss with a flat top? You can then turn some PC rod stock to the required shape/dims and use 3M VHB adhesive for plastic to glue it to the boss that was faced on the visor. ideally you would be able to put a small hole in both sides and glue a metal rod in the center of each to reinforce it.
3M™ Scotch-Weld™ Low Odor Acrylic Adhesive DP8810NS​
T
TT_Vert
Wauconda, IL.
I would have to look closer, I think it sheared in half all the way down. If cannot create a boss I could just bring it down to the visor level and then bond a cut down piece of lexan rod of I can find one and profile as necessary.
T
TT_Vert
Wauconda, IL.
I think @Bigblue&Goldie was suggesting to buy a used helmet to use as a parts donor for the one you want to keep/repair.
Ahh, i did look at that path as well. There are very few out there given this is made for a specific reseller (cycle gear). I have found a few used but they are asking $200 for these things and the visors aren't in perfect shape generally. If I could find a reasonable priced on in my size I'd buy it and keep for a spare and maybe but that hasn't happened. It has to be one of only two models: BILT Evolution Modular / Techno 2.0 Evolution Modular. I've been unable to find contact info for the manufacturer to see if either they have a reseller they could point me to or if another helmet brand they sell used the same visor. The helmet is about 3 years old now so i'm shocked i cannot even get a visor at this point. I'm going to do whatever it takes to continue to ride w/ this helmet though.
Thanks
Dave
Bigblue&Goldie
Yeah, I didn't word that right. I was thinking buy a used helmet to take the parts. I know for my helmet (Impact), the hardware and visor run right around $100. My first race helmet went obsolete and I couldn't get a visor for it, so I understand the issue at hand and it *****.
T
TT_Vert
Wauconda, IL.
The visors for this are $19-$22 so fairly cheap. I'm going to keep my eye out for a used helmet and at the same time probably buy some lexan dowel in a close OD and try to fix this one that way.
Bigblue&Goldie
I feel like my old Bell helmet had a brass insert in the visor that rode in the detents. I could be wrong, but that's what I recall. Also, my current helmet uses a screwed on stub/post for using tearoffs; a similar concept might work for you with your 3d printer.
