Motorcycle repair 108
meatness
Sultan. WA
I picked up a little ATV for the wife. She has wanted one for a while and I figured I would pick up a project that me and the boy could work on.
The quad is a Kawasaki Mojave KSF250 from the 90's. After doing some research I have found two common fail points for it. The kickstart idle gear and reverse shaft gears like to fail and the valves like to tighten up. Okay that may be three things. Of course so far the one I picked up has at least the kicker problem.
Here is the issue.
The idler and the reverse shaft gears are held onto their respective shafts with c clips. They both ride on a brass bushing that is lubricated via oil flying around in the crank case. The bushings fail causing all kinds of issues.
Here is the crank case and the placement of the gears. Notice the gap between the reverse shaft gear and the shaft. This is because the bushing failed and is now missing.
The idler gear shown in this picture is a new gear I purchased to replace the failed idler gear pictured a few below.
Here is a close up of the shafts and the placement of the C clips that hold the gears in place.
This is a reference of where the shafts are in the motor overall.
Here is the original failed idler gear. I did notice that the replacement idler gear is a little different, the gear is wider overall with a wider bore to ride on the shaft. I am thinking that this was Kawasaki's fix for this known issue.
Failed c clip
The 3 gears that I have from left to right, failed Idler gear, replacement idler gear with new bushing, and failed reverse shaft gear.
This is the reverse shaft gear close up. Notice some of the bushing is still crudding up the gear from the failure.
This is a close up of the new gear with the good bushing.
Now here is where I need advice. How would you go about fixing this issue so that it will
A. Not cost a small fortune and
B. Not fail again.
My ideas are this. Machine out the gears to fit a Drawn Cup Needle Bearing that has the correct width and ID to fit the shaft accordingly. I see two issues with this, the cost of machining the gears to fit the bearing and finding bearings that would fit my application. So far after about an hour spent on Grainger on a few others I haven't found anything that would work.
The dimension of the gears.
Idler Gear - ID 19mm exactly, width of the gear that meets the shaft is 9mm.
Reverse Shaft Gear - ID 19mm exactly, Width 7mm.
The bushing on the idler gear is 2mm thick making the shaft 17mm OD on both gears.
The other idea I had was to just fit the new/wider gear hoping that this was indeed a good enough fix and find some material that would work as a bushing for the Reverse Shaft Gear. The issues with this fix are I have no idea where to source the correct material in the dimensions I need to make a bushing and I obviously don't have access to a lathe.
Any advice would be much appreciated. Thanks.
KenS
I don't see a way around this other than to either buy a new Reverse gear with factory bushing, or prepare for some lathe work. The good news is this isn't a big job, and you could probably get by with minimum time at a machine shop-- or perhaps free at a vo-tech school machine shop.
First, you need to mic the Reverse gear shaft for concentricity to be sure it hasn't been damaged by the failed Reverse gear bushing.
This sintered bronze metric oilite bushing has the correct dimensions to allow it to be:
1.) Chucked into a lathe with enough material for parting off.
2.) Bored out one millimeter to 17mm ID.
3.) Turned down to an OD 19mm+ for a press-fit into the existing Reverse gear bore.
4.) Parted off to 7mm width to match the width of the gear.
If you enjoy living dangerously, and if there is enough material in the web of your Reverse gear, you may be able to bore it out to 30mm ID and fit it with a $7 off-the-shelf 6903 ball bearing which is 7mm wide with a 17mm ID-- a custom fit for your Reverse gear and shaft.
Similarly you might be able to get by with a 16003 ball bearing for the Idle gear.
But why not trust the factory fix, and save yourself the trouble and buy a new Reverse gear? I wonder if a new factory Reverse gear would also been widened to 9mm like the new Idler for a more robust mesh.
superspec
WM louisiana
congrats, the mojave was a pretty cool ride for back then except it was down on power and suspension. also they were probably the least sold.
zmaxmotorsports
South of omaha
Is there any reason why you cant tap the hole in center of that shaft and use a button head bolt and an oversize washer/fender washer in place of c-clip to hold the bushing in center of gear,or is there clearance issues with the cover?
Im used to playing with 900/1000 kaws ,never been inside something that small.
But Im sure we can come up with a better than that clip idea:beer:
M
meatness
Sultan. WA
I have thought about the tapping the holes and running bolts in there. I haven't checked the clearances yet. This weekend should allow me some shop time. I will follow up then.
In the mean time thank you very much kens and Max for taking the time to give this some thought. You guys are what make this place so successful. I truly appreciate it and am considering both of your input and suggestions as I take another look.
PWC Repair
Arkansas
I'm betting you could find a bushing from an automatic transmission that would work there with little to no machining. Possibly an inner sun gear bushing. I have a few I'll try to measure tonight.
PWC Repair
Arkansas
Measured the bushings I have, they are all too big. Maybe take the gear with you to a plumbing supply with copper fittings. Surely a bushing or coupling or something would be just about right.
