Mounting 4" square box in drywall question - flush subpanel to conduit transition
I have a flush mounted subpanel in an attached garage that is semi-finished (the three walls of the garage are finished, the rafters above are not). I would like to add a surface mount (in a 4" metal box) nema 14-50 outlet on the opposite side of the garage, running conduit from the subpanel, across the bottoms of the rafters to the opposite side of the garage for a 220V welder.
In trying to figure out how to properly transition conduit through the drywall, reading this website and others, the suggestion was to use a 4" metal electrical box with an extension to connect the conduit through the drywall to the subpanel. Off to my local Home Depot and Lowes and I'm not seeing any stud mounted 4" boxes which allow for the 5/8" drywall thickness.
How would I secure the 4" box to the stud so it's flush? The largest box they had, the mounting holes in the side are not far enough back to screw into the stud AND allow the box to protrude out 5/8 ".
Also the extensions I'm seeing have rounded corners (they're drawn, not welded) so each corner there is a small gap. Is this a concern?
Thanks for your help.
