Recoil Rob
I may ahve bit off a bit much with the new Yost 6" for the garage. Bench top is 2" hardwood and this vise is going to take up quite a bit of space.
What's the procedure for mounting a vise on it's own stand? I have seen them fabricated from square and round pipe stock with a flange on top to mount the vice and another on the bottom to mount to the floor.
What size mount would I need for the 120lb Yost 206? Is there a preference for a square over round pipe upright? What thickness should the wall thickness be? How thick should the end flanges stock be?
What size bolts & nuts for mounting the base to the floor?
I assume they are mounted in concrete floors, whats the best method? Drill holes in the concrete floor, mount threaded rod (or bolts, head down) in the floor and use nuts to hold it down? How's the rod cemented to the floor, concrete or epoxy?
How high off the floor should the vise be and how close to the workbench? What about height of vise in relation to height of bench?
Lots of questions I know but best to get it right the first time.
Two completely different tools used for different purposes...
