Mounting Bench vise A or B?
motorcitykid
Detroit River
My vise is pretty hefty at 130pounds, I’m interested in mounting it so I have two corners of the bench to utilize and have the static jaw flush with on both sides. The bench is over 2,000 pounds made of steel, 4’x9’ so I’m not concerned much about the weight tipping it.
Would you mount the 3 ears inside or to the edge? A or B?
larry_g
oregon
A is going to put you fixed jaw further from the edge than B. My suggestion is to try both ways and see if both work for you or if only one does what you want. The last vise I mounted would only work one way.
lg
no neat sig line
motorcitykid
Detroit River
Both A and B have the same clearances which are marginal as the swivel base flares at the bottom which causes it to stick out 1/8” if I wanted it at a right angle to the face of the table.IMG_2459.jpeg
2oolhound
BC Canada
All my vises have always fit closer using the B position.
If you look at the vise and imagine you have an 1800 lb object clamped in it, if not bolted down the vise would want to roll off the bench. In the A position the front is being held up but all the rest of the stresses run across the 2 side bolts. In the B position the back bolt would also seemingly take some of the load off the 2 side bolts and utilize the strength inherent in the body of the vise in spreading the holding force toward the back. In the A position there is nothing making the back of the vise body beyond the 2 side bolts, hold anything.
Disclaimer: I'm not an engineer
PierceA
Clamp it in place with large 'c'-clamps for a week or two, and decide which you like best.. I think I'd go with B, I agree with 2oolhound's assessment of stresses taken by the mounting ears.
Also: make sure the bottom of the base is FLAT. No bumps or waves. If you need to, use a flat file or put the base in a mill and machine it flat. If there are any high spots, when you bolt it to a steel bench top, it will break an ear off the base.
Pierce.
tarmy
Nor Cal
Pierce.
This. I would temp install as mentioned and see what works for a few projects.
Nice vice too!
motorcitykid
Detroit River
I drilled one hole and utilized one existing from my previous vise and mounted in the b orientation. The reason being that A would require the base being a slight bit setback and I want to have as much useable space beyond the static jaw as possible. So far it’s great, in a perfect world I’d be able to also raise and lower the vise depending on the task I’m using it for.
But, it’s really impressive so far. I appreciate all of your insight greatly.
Sumboodie
AK
Where do the boltholes line up in relation to the vise? I assumed 2 on the side and 1 in back, but that's not making sense with what you drew out.
seber
Deep East Tx.
B. The leverage of a part hanging over the front of the bench will try to tip the vise forward and off the bench. That force is counteracted by the third bolt. That's why it is there. Otherwise it serves no purpose.
