you can mount a piece of shallow unistrut using concrete anchors . Then get some 1/4 " spring nuts and hardware including fender washers to mount your cabinets or whatever it is.
For cabinets mount one piece of strut for bolting the top of the cabinets and another piece for the bottom. If its a whole long wall of cabinets, you can use full 10 ft pieces of strut, level the strut and cabinets will be nice and level. This is also nice because with spring nuts it gives you play side to side so the mounting holes in the cabinets don't need to be dead on and when you mount the strut to the wall you will have a little adjustment up and down as well due to the elongated holes in the strut. If whatever you are hanging is super heavy you can use all 3/8 hardware(anchors,spring nuts, and hardware).
