Mounting large objects on walls...need advice
jeepurzz
LI, NY
I just picked up a 50ft air hose and reel set, but dont know the proper way to mount it on my wall.
It's pretty beefy and has 4 holes for 1/2" bolts. How would you mount this up?
oNFVY9enR52mOvofQ8zRlCjWZmfJlQIxRrpabhS_idPn2NLJ5RQqOYJ7maqcITvMbvnwnbNUmp0JzK8k2z0g7T4bypPMqZJ5PaWEqKETQSUwKK1GiCVhJy3-CX4S5i7Ia8Anz_7CsYHViAKP2t51m-KeuWmiHw
http://lh4.googleusercontent.com/pu...CVhJy3-CX4S5i7Ia8Anz_7CsYHViAKP2t51m-KeuWmiHw
Ray-CA
San Diego CA
I have a similar hose reel. I cut through the dry-wall in the garage and put up a 2x6 across two studs then lag screwed the reel to the 2x6.
Ray
bgott
Houston, TX.
What kind of wall? If it is a regular stick stud 16" OC I would screw a 1x4 or 6 between two studs and then screw the reel to the 1x.
