Mounting manual transfer switch outdoors
jwreels
I have a Generac Homelink that I would like to install. My electrical panel is mounted on the outside of the house. Is there a way to mount this transfer switch in an exterior enclosure?
J
jwreels
The enclosure is a NEMA 1 and the power inlet box is a NEMA 3R. I need the enclosure to be outdoor rated.
Stuart in MN
Minneapolis
I looked at the owner's manual for the Generac Homelink panel, it's rated NEMA 1 for interior use. To use it outdoors you'll have to purchase and install a separate NEMA 3R rated enclosure, and then mount the Homelink panel inside that. The enclosure that Pattenp linked above should work, or something similar.
J
jwreels
slow
near Orlando
can you mount it on the inside opposite of your panel? Not sure if it backs up to a garage or living space.
J
jwreels
No it currently has to be on the outside. The inside of that wall is the living room.
oltruckag
*******, GA
I can get you a deal on a Hoffman 20x20x8 N3R
Alps - Hoffman 20x20x8
Part of my business is a control panel shop, don't mind helping a GJ member out. Send me a PM if it would work for you.
Tyson
