Homewrecker
I know some people on here have this Emergency Stop Button mounted on their lift but was unable to find the pics I had seen at some point.
Anyone have suggestions on where/how to mount this?
I was thinking of mounting it to the side of of the enclosure that contains the Contactor and button but there is very little room inside and any protruding fasteners may interfere with the wiring inside.
Also, the manual states a 240V / 30 Amp Circuit is required which I have running to the post via 10/2 Cable yet the lift came with a 14/2 SOOW pigtail on the power unit. I'm going to run the 10/2 I have installed to the emergency stop switch but should I just connect the existing 14/2 pigtail from the box onto the other side of the switch or remove the pig tail and run 10/2 from there was well?
The only issue with running the 10/2 into the power unit box is the nylon compression fittings I have don't fit the existing knockouts on the box.
