mod600
I'm planning on mounting three 8' T8 light fixtures end to end in my shop. Basically making a 24' run of lights. What is common practice for mounting them end to end?
Mine have 1/2" knockouts on each end. I picked up some box spacers at Menards to put in between each fixture to mount them together, see below link:
http://www.menards.com/main/electri...-fittings/1-2-box-spacer/p-1442229-c-9538.htm
I believe this would work, but there'd be a small gap in between each fixture. A buddy of mine just took a standard straight connector and removed the set-screw and installed it from the inside of one fixture, so the threaded end was on the outside, the slid the other fixture on, secured them together with the nut and added the plastic bushing nut. This seems like it'd work too and keep them tight together. Or is there a better way to do this?
Thanks!
mod600
Thanks!
mod600
