mounting these wiremold strips....
dogdog
Any one know how these wiremold strips are mounted.... I got 3 in vacious length 15AMP 20AMP strips from 6 ft or 8 ft strips some how....but how do you mount them? I don't see any tabs that to use screws on them.... is there some missing brackets? these are design for industrial racks so not sure, if there are brackets to them or not. I just got them long ago....
one of them is wiremold UL2063BD
Norcal
You asking about Plugmold® ? They have mounting holes in the back channel, they will have to be opened up to mount, have fun when doing so to one not fastened down. :evil:
D
dogdog
alfredeneuman
Fullerton, CA
If it plugs in, it's classified as a relocatable power tap (power strip) and can't be permanently affixed. That's why it doesn't have any holes in it.
Some power strips have keyhole slots in them, to hang off of untightened nails or a screws.
There has to be a way to detach the strip without using tools.
Just a suggestion, order the proper clips from Wiremold.
D
dogdog
yes, was trying to find that correct clips... I have 3, all different size but all wiremold strips... all don't have holes clips mounts, don't remember where I got them from, found them in my basement been there at least 10 years maybe... trying to organize my non industrial table workbench..... It's industrial stuff, figure some one should know how these things are mounted up.
BTW thx for the link....
nadogail
Coronado, CA
I disassembled the strip I acquired from a thrift shop, drilled holes through the back panel to mount them to my bench.
I connected a length of 12 gauge 3 conductor cord to the strip and bolted it to the overhead shelf on my bench.
I completed the job by painting the cover and slapping it in place.
That was, I think, in 1978.
alfredeneuman
Fullerton, CA
An alternative would be to bend a pair of "Z"- brackets, fasten them to the wall.and cradle the wiremold in them.
beatgr
Detached from building
LeGrand - Wiremold Workstation Power Strips Wall Mount Kit (Pkg of 3)
part number: 08004BULK
08004BULK Product Description: SNAP ON SLIDE OFF MOUNTING BRACKET;
Product Range:- Accessory Type: Power Strip Wall Mounting Bracket with Screw; Features: Three (3) aluminum brackets with screws;
For Use With:power Outlet Strips (LeGrand / Wiremold)
Wiremold stopped production of product in 2014, reaching EOL in 2017.
Distributors:
Mouser marks Obsolete.
Newark/Avnet has some remaining stock, ~20 kits as of November 2020.
Wiremold still manufactures the UL2063BD (after almost 50 years).
Now manufactured in Mexico.
Wiremold UL2063BD
Twenty-four outlets, rugged gray aluminum housing, 15A, 6' (1.8m)
14/3 SJT black cord with NEMA 5-15 plug. Length of Strip 72'' (1.8m).
Receptacle center-to-center spacing 2 1/2'' (64mm).
